1st Feb 2015, 9:03 pm | #1 |
Unidentified rack units with air pumps in them
I have no idea what these units are. They were received with a lot of radio, comms and miscellaneous items. They might be related to this plotter/recorder unit as it was in a similar coloured surround I think?
https://www.vintage-radio.net/forum/...d.php?t=112588 These could have been part of some test equipment used by the Buildings Research Establishment but I can't be sure... There is something square missing from the front panels, and the motor appears to be an air pump with two terminals on the front to attach rubber pipe to. Any suggestions appreciated, thanks! |
1st Feb 2015, 9:16 pm | #2 |
Re: Unidentified rack units with air pumps in them
Looks like a diaphragm vacuum pump - probably as part of a gas analyser?
1st Feb 2015, 9:18 pm | #3 |
Clashed with Sean!
1st Feb 2015, 9:21 pm | #4 |
Thanks... any ideas of uses for them? Either just the rack units or just the vacuum pumps. Or even both together!
Seems a shame to scrap them... |
1st Feb 2015, 9:28 pm | #5 |
If they are standard 19" racks then they are useful.
1st Feb 2015, 9:33 pm | #6 |
I will check the measurements.
2nd Feb 2015, 12:55 am | #7 |
I very much suspect it was part of an infra-red gas analyser. In the days before helium mass-spec was used for leak detection, it was common to use nitrous oxide gas and detect its intense infra-red absorption peak. I inherited a couple of complete units back in the day when I worked in the nuclear power industry.
B Last edited by Brian R Pateman; 2nd Feb 2015 at 6:41 am. Reason: Relevance. |
2nd Feb 2015, 12:52 pm | #8 |
I'm sure I've seem similar pumps in old vacuum desoldering stations, I'm sure somebody would want them.
Jim |
2nd Feb 2015, 3:01 pm | #9 |
I doubt they will exert sufficient suction; all they did was suck in a "breeze" of gas. They depend upon some soft rubber diaphragms which tend not to age very well and I'd guess they were made in the 50's or 60's. I have an identical-looking pump in my garage but I've never used it for anything. Might be useful for oxygenating a large aquarium? When I got the complete units, I did wonder if they could be adapted to analyse car exhaust gas (CO), but it would have been quite a conversion; they were gas-specific. IIRC, on the electronics side there were two or three ECC8x's and I think they worked by beating two oscillators against each other; the infra-red gas cell effectively being a pressure-dependent variable capacitor. They employed a constant-voltage mains transformer and the whole assemblies were pretty heavy! A complete one in working condition would be collectable; good example of a technology that was quite clever but was soon superceded.
B |
2nd Feb 2015, 3:50 pm | #10 |
