Reply
Old 14th Apr 2024, 1:33 pm   #1
Floejoe
Default AVO EA113 help required.
Hello to everyone,
I have just dis-assembled my AVO EA113, to re-fix a loose scale plate mirror and in the process of freeing the two stacked PCB's from the switch spindle neglected to make a proper note of the resistance range switch drive collar and fibre washer position.
The item that I am referring to is the small black plastic collar with lugs which locates into the resistance range wafer switch on the DC/AC amplifier board and not the main range selector wipers on the top board. I just need to know which way up the collar sits on the spindle and if the fibre washer is before or after it. I have managed to obtain a service manual but it does not seem to show the lugged collar at all in the exploded assembly diagram.
Grateful for any assistance.
Joe,
Floejoe is offline   Reply With Quote
Reply
