Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Offered (private sellers only, exact price required, no swaps)
Sets, Parts and Service Information Offered (private sellers only, exact price required, no swaps) You may announce components or sets for sale or offered free here. Private collectors only - no traders. You must include an exact price. No swaps.
Old 17th Apr 2024, 9:26 pm   #1
whiskas
whiskas's Avatar
Default More components and radio parts - Have a browse!
Hi all,
My thindown continues...
All items are first come basis (No hat)
P&P: small, slender items:
Large letter £2- £3
Small parcel £4 (up to 2 kilos packed)
(As always, I'm happy to combine postage to save you £s on postage.)
Please leave message in the thread and PM with your requests, thanks
...where on earth did that spring/screw go??
whiskas is offline   Reply With Quote
Old 17th Apr 2024, 9:48 pm   #2
whiskas
whiskas's Avatar
Default Re: More components and radio parts - Have a browse!
1. Radio badges:
Murphy, Stella, Philco, Roberts
Please request specific badge required)
£2 each + post
2. 2x Radio grilles, ~140mm wide
£3 + post
3. 20x SRC 150pf silver mica caps. 200V working.
New old stock
£3 + post
4. 13pcs Wima 0.22uf 100V MKS2 5mm pitch polyester caps
£2 + post
5. 20x Philips 3300pf 160V 1% polystyrene caps.
Extended foil design, super quality!
£3 + post
ID:	296471   Click image for larger version
ID:	296472   Click image for larger version
ID:	296473   Click image for larger version
ID:	296474   Click image for larger version
Old 17th Apr 2024, 9:49 pm   #3
whiskas
whiskas's Avatar
6. 10x 47pf 350V epoxy dipped Silver mica caps. 1% tolerance
£3+ post (3 lots available)
7. 6x Nichicon 33uf 450V electrolytic capacitors.
Reliable, great for replacing old 32uF HT caps, etc
£3 + post
8. Lot of 22pf polystyrene capacitors.
Qty as shown (about 40? pcs)
£3 + post
9. 12x Lemco 470pf 160V polystyrene capacitors
£3 + post
10. RS ZN1034E New old stock Precision timer/counter IC
Hard to find now! (Only one left)
£3 each + post
ID:	296476   Click image for larger version
ID:	296477   Click image for larger version
ID:	296478   Click image for larger version
ID:	296479   Click image for larger version
Old 17th Apr 2024, 9:51 pm   #4
whiskas
whiskas's Avatar
11. 2x RS 6.8mH 2A Suppression chokes, new in pack.
£3 + post
12. 20x 1000pf 63V 1% polystyrene capacitors
£3 + post
13. Valve screening cans, all in good condition. B9A and B7G types
£3 + post
14. 20x Panasonic FM 100uf 50V 105C low impedance electrolytic capacitors. Among the best types currently available for reliability, etc. Ideal for SMPS, audio etc.
£3 + post
15. Mullard AF114/AF117 transistors. (Lot 1 3x AF114 + 7x AF117)
Taken from scrapped radios, untested.
£3 + post
ID:	296481   Click image for larger version
ID:	296482   Click image for larger version
ID:	296483   Click image for larger version
ID:	296484   Click image for larger version
Old 17th Apr 2024, 9:53 pm   #5
whiskas
whiskas's Avatar
16. Mullard AF114/AF117 transistors. (Lot 2 2x AF114 + 8x AF117)
£3 + post
17. 7x Metal can 741 op-amps, 1970's date codes
3 look used, 4 look unused. Quite scarce now!
£4 + post
18. 3x loudspeakers, ex transistor radios.
25 ohm, 5 ohm, 3 ohm. Cones in good undamaged condition
19. 5 pin internal power plug for radio.
£2 + post
ID:	296488   Click image for larger version
ID:	296489   Click image for larger version
ID:	296490   Click image for larger version
ID:	296491   Click image for larger version
Old 17th Apr 2024, 9:54 pm   #6
AnalogueMan
AnalogueMan's Avatar
Item 1 - the Stella Badge, plus item 7 - 33uf 450v caps, just one lot please so the second still up for grabs.
Many thanks, Alan
AnalogueMan is offline   Reply With Quote
Old 17th Apr 2024, 9:55 pm   #7
whiskas
whiskas's Avatar
20. 50x Thomson 22nf 0.022uf 50V Monolithic ceramic caps.
Ideal for digital decoupling etc. Top quality
£3 + post
21. 3. 8x United Chemi-con 50uF 30V @ 125C, ultra reliable caps with Teflon end seals! These are the business for valve cathode bypass, etc.
£4 + post ( 2 lots available)
22. 30x Mullard 22nf (0.022uf) Miniature Ceramic capacitors. Very popular handy value. Quality NOS parts.
£3 + post
23. Lot of 6 tuning caps, ex exquipment, all in good condition
£7 + post
24. 6x NOS Omron Double Pole relays..
Fully sealed, Made in Japan, super quality
£4 + post
ID:	296493   Click image for larger version
ID:	296494   Click image for larger version
ID:	296495   Click image for larger version
ID:	296496   Click image for larger version
Old 17th Apr 2024, 9:57 pm   #8
whiskas
whiskas's Avatar
25. 15x Mullard 680uf 10V 108 Series Long life capacitors.
Excellent caps. Measure fine.
Ideal for replacing 470uf 500uf caps.
£4 + post (or 3 lots for £10 +post)
26. Lot (1) of six ferrite rods with coils
£5 + post
27. 5x NEC 24V Double pole relays.
Fully sealed, made in Japan. top quality
£4 + post
28. ALPS 50K stereo 9mm square potentiometer.
Ideal volume control for audio equipment
New in sealed RS pack
£3 + post (2 available)
29. Lot (2) of six ferrite rods with coils
£5 + post
Name:	mu 680uf 10v.jpg
ID:	296498   Click image for larger version
ID:	296499   Click image for larger version
ID:	296500   Click image for larger version
ID:	296501   Click image for larger version
Old 17th Apr 2024, 10:13 pm   #9
bc312
bc312's Avatar
Could I take the following please:
£3 + post
Have sent you a PM.
Thanks
Mike
Leave me alone - I know what I'm doing.
BVWS member, EUG, G-QRP
Radio Bygones/Radiophile
bc312 is offline   Reply With Quote
Old 17th Apr 2024, 11:52 pm   #10
VT FUSE
Hi Rob
Please may I have the following lots:
Lot 8 - 22pF polystyrene caps
: 14-50uF Panasonic caps
: 16- AF114 / AF117 Transistors
: 21 -50uF Chemi-Con caps x 1 lot
Will pm you now as per usual
Mike
VT FUSE is online now   Reply With Quote
Old 18th Apr 2024, 8:51 pm   #11
qualityten
Hi Rob,
Please may I have:
Item 3. 20x SRC 150pf silver mica caps. 200V working.
Item 6: One lot of 10x 47pf 350V epoxy dipped Silver mica caps;
Item 28: One or both of the Alps 50k pots.
Thank you. Will send PM.
qualityten is offline   Reply With Quote
Old 20th Apr 2024, 4:05 pm   #12
whiskas
whiskas's Avatar
Some items sold, items still available are:
1. Radio badges:
(Philco badge only left)
£2 each + post
£3 + post
£2 + post
£3 + post
£3+ post (2 lots left)
£3 + post
£3 each + post
£3 + post
£3 + post
£3 + post
£3 + post (3 lots left)
£4 + post
£2 + post
£3 + post
£3 + post
£7 + post
£4 + post
£5 + post
£4 + post
£5 + post
Old 21st Apr 2024, 6:48 am   #13
BenHoper
Hi, can I take 5, 3n3 caps
And 17, 741 op-amps please. Will PM.
Thanks Ben
BenHoper is offline   Reply With Quote
Old 23rd Apr 2024, 8:51 pm   #14
whiskas
whiskas's Avatar
All items in list are still available (post #12), except #17 (741 opamps) and #24 (Omron relays)
