Old 15th May 2019, 9:57 pm   #21
trabant
Default Re: Mystery 1930s Philco name that Resistor ??
The loudspeaker appears to be original and permanent magnet I shall fit a 400 and see how we go when it's new electrolytics arrive
trabant is offline
Old 15th May 2019, 10:03 pm   #22
Boater Sam
U647 diagram uses a 304 barreter, no resistors connected to it, why would there be? I'ts on the AC part, filaments ballast.
However there is a 400 ohm resistor in the tone network, R23.
Not suggesting that this is the set, we have not even got a picture of the radio but Philco made lots of sets witH 304 barretters and many parts of the circuit will be common.
Boater Sam is offline
Old 17th May 2019, 8:04 pm   #23
trabant
To whoever asked if I'd got the model number correct yes I have and no I can't find any reference to it either the chassis seems to be loosely based on the v537
ID:	183281   Click image for larger version
trabant is offline
Old 17th May 2019, 9:02 pm   #24
Andrewausfa
Andrewausfa's Avatar
Just thinking out aloud but this must be a rare old set if no-one can find anything on it on the net and no-one's popped up with 'I've got one of those'.
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 18th May 2019, 7:24 am   #25
crackle
It is certainly worth recording the details in the radio museum..
If you send them to me I will setup a new model page.
Mike
crackle is offline
Old 18th May 2019, 8:24 am   #26
Hoveradio
Hoveradio's Avatar
Just found the IF frequency for this set on Radiomuseum.Listed as 465khz.
http://www.radiomuseum.co.uk/pif.html
John.
Made in England.Repaired in Wales!
Hoveradio is offline
Old 18th May 2019, 8:29 am   #27
Herald1360
Herald1360's Avatar
Which is in itself quite uncommon for Philco and also quite "British".
Has the OP revealed what the complete valve lineup is yet?
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 18th May 2019, 8:39 am   #28
Hoveradio
Hoveradio's Avatar
Looking at the label on back of set,line-up is:
6A7 78E 75 18E 25RE & 301 or 302 Barretter.
John.
Old 18th May 2019, 9:08 am   #29
Argus25
No Longer a Member
Originally Posted by trabant View Post
Right well after cleaning it would appear to be yellow body black tip brown band which I make 400 ohm . The resistor is connected at one end to the fuse on the chassis and via another resistor to the barretter.
Of course it is, check post #6 and #11
Argus25 is offline
Old 18th May 2019, 11:23 am   #30
Station X
Station X's Avatar
We've got beyond that stage. The OP is now trying to figure out why the recapped set doesn't work:-
https://www.vintage-radio.net/forum/...d.php?t=156594
Graham. Forum Moderator
Station X is offline
