5th Sep 2007, 2:13 pm | #1 |
Pioneer PL-12D turntable maintenance
Hello,
I seem to be reliving my youth as I had one of these 30 odd years ago, my first hi-fi turntable in fact, and at Tonbridge last Sunday I got another one which is in unmarked condition, for £20. It's original cartridge/stylus is worn so I will probably replace that with an AT110E but essentially the deck is working OK. Has anyone got a repair manual for the PL-12D please, I suspect it needs very little maintenance but it looks not to have been touched so it may be prudent to overhaul it before I put into use. Thanks. Howard Last edited by howard; 5th Sep 2007 at 2:19 pm. |
5th Sep 2007, 2:20 pm | #2 |
Re: Pioneer PL-12D turntable maintenance
Hello Howard,
No repair manual I'm afraid, but I think I have the original PL-12D instruction manual somewhere. I can make you a copy if needed. Michael |
5th Sep 2007, 3:05 pm | #3 |
Hello Michael,
A user manual would be very useful, as I can't remember how to use the overhang checker etc. Please let me know if you manage to find it .... many thanks. Howard |
5th Sep 2007, 4:59 pm | #4 |
Hello Howard,
I found the manual and have made a copy. Please can you send me a PM with your address, then I can pop it in the post! Michael |
5th Sep 2007, 6:08 pm | #5 |
Thanks Mike,
I've sent you a PM about the user manual. Has anyone got a repair manual or knows roughly what needs to be lubricated/cleaned/tightened on this record deck ? Thanks. Howard |
5th Sep 2007, 6:18 pm | #6 |
Hello again,
I've bought a service manual off eBay from the USA for £7 inclusive so this thread can be closed. If anyone wants a copy of it when it arrives send me a PM. Howard |
5th Sep 2007, 9:24 pm | #7 |
Hi Howard,
a lovely straight forward turnatable you've got yourself there. Worth as much for its lid now as anything else! Not much to go wrong apart from the belt, obviously, and also watch out for the centre shaft. If you remove the platter and belt, run the side of your finger along the shaft of the centre shaft applying pressure (slight) on the opposite side of it from the motor pulley in the direction of the motor (if you understand me!). We used to get them when they would be worn at one point and you would get a "sticking point" at one place in the revolution, perhaps caused by it being left too long idle with the belt in place pulling the whole shaft/platter assembly toward the motor, that was allways my boss' theory anyway. Unfortunately the centre shaft is no longer available from Pioneer, though someone may have some. A thoroughly good clean and re-lube usually sorts it out if not too bad, and don't leave the belt on during prolongued times of innactivity. Oh, and the cartridge contacts may need a clean. Apart from that not much that some good use won't put right. Like most things, lack of use can be worse than over-use. Cheers, Percy |
6th Sep 2007, 2:22 pm | #8 | |
The lid hasn't got a mark on it, remarkable for a deck this old ! I've checked the centre shaft (which I did at Tonbridge) and it seems fine, no roughness at all and indeed the platter goes around at a perfect constant speed. I did put a couple of drips of oil down a little hole under the platter as directed by the label next to it and I have removed the wiring and cleaned all contacts in the headshell. I also rebalanced the arm, repositioned the counterweight which was loose and had moved, and set the tracking weight to 1.5 grams. Just playing Pink Floyd Dark Side of the Moon on it now and it sounds brilliant, it's not so worn Stanton 500 cartridge is still going strong It's good to hear music on vinyl on one of these Pioneer decks again .......... Howard Last edited by howard; 6th Sep 2007 at 2:49 pm. |
30th Dec 2007, 1:36 pm | #9 | |
I would appreciate a copy if possible. Also, my PL-12D doesn't have a cover. Would you have any idea where I could get one from? Malleson |
30th Dec 2007, 3:17 pm | #10 |
I had a PL-112 version of this, a slightly later model I believe and it was excellent, it had to be assembled out of the box. I fitted a Shure M75ED to it which gave a superb performance.
I now have a Pioneer PL-760 direct drive with its own Pioneer cartridge and Pioneer SA-760 Amp. Your deck was a great find, I hope you get lots of pleasure from it (the Shure cartridge would be my choice!). For maintenance just a drop of light machine oil on the bearings, motor and pivot points should be all that is required, and redistribute any grease that is already on the mechanism. |
1st Jan 2008, 8:39 pm | #11 |
1st Jan 2008, 11:10 pm | #12 | |
Send me a PM please and I'll send you a copy. I need your email address. Sorry, no idea where a replacement lid can be obtained other than from another scrap PL-12D if you can find one. Howard |
2nd Jan 2008, 8:17 pm | #13 |
Hi Howard,
I was taking the garden rubbish to the recycling centre (aka the tip) this morning and whilst I was unloading my car I noticed a nice looking turntable, and looking at the pictures on this thread I believe it's a PIONEER PL-12D. It was in good condition and was only £2 so I thought I'd give it a go. I haven't tried using it yet because the wife doesn't want it in the house - it's sitting in the garage but I'm going to clean it up and give it a go (although I haven't got any speakers). I'll post a photo once cleaner. I would appriciate any manuals/data you have so I can give it a good service. If it doesn't work i'll give it away for parts. Would also like to know what an overhang checker is and how to use it? Many thanks, Matt (Please PM me for my email address) Last edited by mcourtman; 2nd Jan 2008 at 8:26 pm. |
2nd Jan 2008, 8:27 pm | #14 |
2nd Jan 2008, 10:20 pm | #15 |
Just spent the last hour and a half cleaning up my bargin purchase and it's scrubbed up really well, including the lid. I have attached 4 photos.
It is a Pioneer PL-12D turntable and it has a Shure ED T2 cartridge fitted, only thing is it doesn't have a belt so I cant test it. Any idea where I could obtain one of these? Not really sure why I brought this but I couldn't just leave it sitting at the tip. Thanks, Matt |
3rd Jan 2008, 4:28 pm | #16 | |
you will need to use a piece of string to measure the length of the original belt. once thats done, these belt are readily available online. good luck and nice work! |
4th Jan 2008, 2:30 am | #17 |
as luck would have it just stumbled on this:
http://www.retrohifi.co.uk/pioneer_pl12d.html |
4th Jan 2008, 7:35 pm | #18 |
Thanks for that Ben. I've got a replacement belt from eBay and it works fine. Only problem is, as Nick pointed out, I need an amplifier.
One question though: In my front room I have an Aiwa Hi-Fi that I purchased in the 90's. It's an all-in-one unit with a Aiwa PX-E855 turntable on top - I removed the turntable and connected the Pioneer PL-12D turntable to it but even with the volume up quite high I only got a quiet output. My question is why does the Aiwa turntable play loudly but the Pioneer play quietly. Is there a 'pre-amp' somewhere in the Aiwa? Thanks, Matt |
4th Jan 2008, 7:54 pm | #19 | |
4th Jan 2008, 9:37 pm | #20 | |
Send me your Email address via a forum PM and I'll send copies of both the PL-12D manuals that I have here. New belts for the PL-12D can be found on eBay for £6-£7 inclusive. Howard |
