Old 27th Sep 2014, 1:11 am   #1
electroanorak
electroanorak's Avatar
Default Energy saving lamp warning
Just thought I would mention this....
I have been servicing and calibrating my Racal True RMS Milivolt meter and having problems with odd readings. It was just by chance that I moved my anglepoise bench lamp out of the way to get to the controls of my signal generator. As I moved it, the readings changed dramatically.
Of course, there is an energy saving lamp in it. I removed it and replaced it with a 40 watt reflector lamp and the calibration error was no more.
Just beware when using them near sensitive equipment.
Daniel.
electroanorak is offline
Old 27th Sep 2014, 1:37 am   #2
Refugee
Refugee's Avatar
Default Re: Energy saving lamp warning
I have a magnifier lamp from Maplin when they were on special offer at half price.
All I have to do is drape a scope probe over it with the scope switched on and a clean triangle wave is clearly displayed at something between 30 and 60Khz.
It makes for an easy signal injector when fixing AM radios by lowering it over the circuit board.
You need to be aware of this and there are advantages to be gained too.
Refugee is offline
Old 27th Sep 2014, 2:08 am   #3
G8KBG Tony
Daniel,
Thanks for passing this on. Could save loads of head-scratching.
Tony.
G8KBG - BVWS Member - BATC Member
G8KBG Tony is offline
