28th Jul 2012, 10:20 pm | #1 |
Voltages on Cossor 484 mains radio
Hello again, Can anyone please tell me the voltages I should have within reason on the anode and screen on V 2 MSPen B, 7 pin.
Thanks again Dick. |
29th Jul 2012, 12:32 am | #2 |
Re: Voltages on Cossor 484 mains radio
The Cossor service data gives the following voltages when read using a 1000ohms per volt meter (though it doesn't say whether it's used on its 30V, 300V or 600V range to get them):
Anode 80V Screen 20V Since the anode has some 200K and the screen 1Meg to the HT supply, I would think these readings are more meter dependent than actual electrode voltages. Measuring the voltages between anode and screen and HT+ with a decent DVM and comparing the results when divided by the relevant resistances with the expected anode and screen currents of 0.9 and 0.2 mA may be more informative.
29th Jul 2012, 12:35 am | #3 |
Hi Dick, The Cossor MSPenB is a straight RF pentode. Infomation can be found here:
www.r-type.org/exhib/aad0250.htm It would appear that the screen grid voltage is much lower than the anode. Typ: Vsg = 100 Va = 250. DFWB. |
29th Jul 2012, 12:53 pm | #4 |
Hi Dick my ref book states Anode 200v and Screen 100v , Mick.
29th Jul 2012, 6:27 pm | #5 |
Duplicate threads merged and some posts, which are no longer needed, deleted.
31st Jul 2012, 11:48 pm | #6 |
Hello again, Does anyone know where I might get the page of the 484 service sheet with capacitor values on it. It is not on the service data on the top of this page. Regards Dick.
31st Jul 2012, 11:59 pm | #7 |
Hope this helps, note that some values are not available and, for example, 0.0003uF would be replaced with a 0.00033uF or 330pF.
1st Aug 2012, 11:44 pm | #8 |
Thanks Top Cap and thanks to everybody that has helped with my query. Dick. |
6th Aug 2012, 7:33 pm | #9 |
Hello again, I am still trying to get my 484 working, and I wonder if someone could please verify the following,V 1 41STH (7 pin) anode pin no., osc.anode pin no. and screen pin no. V 2 MSPenB, (7 pin) anode pin no. and screen pin no. V 3 420T, (7 pin) anode pin no, and screen pin no. Regards, Dick.
6th Aug 2012, 8:57 pm | #10 |
Try these:
41STH http://www.radiomuseum.org/tubes/tube_41sth.html MS PEN B http://www.radiomuseum.org/tubes/tube_mspenb.html 420T http://www.radiomuseum.org/tubes/tube_42ot.html
13th Aug 2012, 11:41 pm | #11 |
Hello again,
Still not sorted with my 484. I got to the stage that I was getting very clear but very low sound on Radio Eireann, longwave. I started checking resistors. R7 seemed burnt so I took it out and checked it. It read 245K but on Wireless Trader it reads 25K (Osc. anode load). I replaced it with a 25K which gave no sound. I put back in the original resistor but alas no sound. The osc. anode voltage on the 41STH is 96 volts yet on the Trader sheet it reads 220 volts. Any advice? Dick. |
14th Aug 2012, 8:39 am | #12 |
From Trader 252, the anode load is R8 (25K). If the anode is 96V, the voltage across R8 will be about 250-96V or approx 150V. I=V/R so the current is about 6mA.
The Trader 252 quotes 145V (4.5mA) for the anode. The oscillator amplitude is automatically controlled by rectification of the signal on the grid which creates a -ve bias for the valve. 6mA would be quite reasonable if the oscillator was not working and the grid was biased at 0V wrt cathode. I suggest the following: - If you have not already done it, replace C3, C4 & C6 - Clean the waveband switch and pins and socket of the 41STH - Measure the HT voltage. - Measure the voltages on all pins of the 41STH Cossor made cheap sets and economised on parts. Most sets have decoupling for the oscillator anode supply. I would try adding a 0.1uF 630V from HT to earth. |
14th Aug 2012, 3:03 pm | #13 |
I have checked C3, C4, C6 and cleaned contacts. I will check voltages on 41STH, and also m/a and report back. Does it matter where I connect 0.1 capacitor to earth? Thanks again. Dick. |
14th Aug 2012, 10:17 pm | #14 |
I suggest you keep it near to V1 on the HT end of R8. Have you replaced the electrolytics?
15th Sep 2012, 10:18 pm | #15 |
Hi again, Still no sound on Cossor 484, well this is really not true, I have plenty of sound but not stations on any band. I now know that the frequency changer is working as I tried it in another set. I substituted valve 2, MSPenB with a similar valve but this made the buzzing worse.
When I put my finger near V2 the buzzing gets louder, and, when I put my finger on the top cap the noise gets much louder still. I have replaced all resistors, 3 electrolytics, and all ordinary capacitors. More help would be greatly appreciated. Regards, Dick. |
16th Sep 2012, 7:22 am | #16 |
Hi Dick
Just a quick suggestion have you checked R6 ( The gain control? ) It's in the Cathode circuit of the FC. These are a bit prone to going open circuit. If it is open circuit you will find that the Cathode of the FC is at a high voltage. As a quick and dirty test you could put a 2.2K 1W resistor in parallel with it. It could be that before you replaced the Caps C3 and or C6 were leaking enough to keep it sort of working. Cheers Mike T
16th Sep 2012, 12:00 pm | #17 | |
16th Sep 2012, 10:00 pm | #18 |
Hi, I am going to take all voltages again. It says on the service sheet that they should be taken with the volume at minimum and the lower end of the medium wave with no signal. I have also noticed that the hum noise is greater when the volume is turned down and the long wire ariel is plugged out. Could the volume control be wired wrong way to earth. All resistors have been replaced as circuit. Dick.
17th Sep 2012, 9:31 pm | #19 |
Dick here again, Valve voltages are as follows:-
V1 Pin 1=194 pin 2 98 pin 3 223 pin 6 103 pin 7 305. V2 Pin 1= 0 pin 2 113 pin 3 0 pin 6 0 pin 7 30. V3 Pin 1= 0 pin2 0 pin 3 305 pin 6 5.5 pin 7 287. Rectifier Pin 1= 350 pin 2 351 pin 3 411 pin 4 409. The heater pins measure 2.16 to chassis. When I put my finger on to chassis and move it I get a scraping in the speaker. Hope someone can enlighten me further. Dick. |
19th Sep 2012, 12:18 am | #20 |
Hi Cobault, Would I be right in thinking that you mean R 5 instead of R 6.Regards,, Dick.
