7th May 2011, 6:46 am | #1 |
New Test Card DVD to Download
Hi all.
I'm not sure if this is the correct place to post this, but here goes anyway... I've put together a test card DVD which is small enough to download. I've put it together in a bit of a strange way and I'd be pleased to hear of people's experiences regarding compatibility etc. It's only version 0.1 so I may end up modifying and writing the images a different way if it proves not to be very compatible, although this may make it much bigger and probably not downloadable. Please excuse any poor asthetic or technical design - I'm not much of a design person, but hopefully it should work anyway and I'm happy to listen to people's advice or criticism etc. It has on it test cards C,D,F,J and a few other odds and ends. It can be downloaded as an ISO image from here: http://www.oldtechnology.net/misc/MD...d_DVD_V0.1.iso I've tried it in a couple of DVD platyers and it's worked okay. You select the test card you want and then that will stay on the screen until you select "Root Menu". If the image has been on the screen for a while, the DVD may have spun down so it may take a few seconds for the root menu to reappear, but this way it saves the laser if you have the patterns playing for a long time. Thanks everyone. Kind regards. From Mike.
G7TRF |
7th May 2011, 8:21 am | #2 |
Re: New Test Card DVD to Download
Hi Mike thanks for the download , mine works fine .
Regards .Gary . |
7th May 2011, 8:56 am | #3 |
works great for me too
"Oh yes I love television, all those wiggly lines"! |
7th May 2011, 12:53 pm | #4 |
Thank you great dvd good quailty,brings back a few memories test card f convergence problems
7th May 2011, 1:24 pm | #5 |
Many thanks
7th May 2011, 4:23 pm | #6 |
Works great on LG BluRay player. Great job of DVD Menu editing!
The 1st Colour testcard looks a bit dirty though. |
7th May 2011, 4:31 pm | #7 |
Works a treat, many thanks for that.
Chroma 04 |
7th May 2011, 4:32 pm | #8 |
Top Job Mike. A very useful addition to my "test cards".
7th May 2011, 5:25 pm | #9 |
Probably something I am doing wrong. I tried to screen grab the experimental colour card and although I grab the entire card only half of it is pasted onto the clip board. I tried both MSPaint and Irfanview.
7th May 2011, 6:04 pm | #10 |
here you go
7th May 2011, 6:09 pm | #11 |
Thanks OTT. What did you grab it with? I have an idea my pc is running out of memory.
7th May 2011, 7:06 pm | #12 |
Wonderful! Thank you so much Mike - it works flawlessly and the menu system is spot on!
7th May 2011, 7:38 pm | #13 |
Mine works fine. Great DVD many thanks.
Dave |
7th May 2011, 7:46 pm | #14 |
I have just got around to downloading/burning this too, superb test cards and additional bits, I too became a bit nostalgic when I saw the cross-hatch pattern! Just one thing, should there be any sound? there is an audio file showing on the extracted disc but I have no sound, this could well be the way that I have extracted and burned the disc though Regards Andrew |
7th May 2011, 9:38 pm | #15 |
Just downloaded it and thought I'd try playing it on my laptop using DaemonTools Lite and Media Player classic, the former recognises it, Windows opens it as a DVD, but MPC says incompatible region and/or codecs...
Probably just my computer, I'll burn it off later and give it a whirl in a DVD player... |
8th May 2011, 11:24 am | #16 |
What a great idea. Sorry for the numpty question but I'm struggling to get this format of file to run - whats the best way of burning the file onto a DVD? Thanks!
"I need someone to protect me from all the measures they take to protect me..." |
8th May 2011, 11:26 am | #17 |
ISO files are disk images. I use a program called Imgburn to burn ISO files to CD/DVD http://www.imgburn.com/index.php?act=download
8th May 2011, 12:20 pm | #18 |
Thanks Jeffrey - that did the trick!
Thanks Mike too - thats really good.
8th May 2011, 1:40 pm | #19 |
Thank you Mike, just downloaded test cards and burnt them to disc, they look fine.
Victor. |
8th May 2011, 8:53 pm | #20 |
Thanks everyone for the replies and kind comments. I'm glad it seems fairly compatible with various DVDs as I was a bit worried it wouldn't be.
Thanks again all. Kind regards. From Mike.
G7TRF |
