20th Feb 2009, 2:50 pm | #1 |
Philips CP 3691 schematic.
I need the schematic for a model CP3691 philips radio any help would be apreciated.
Lee |
20th Feb 2009, 4:27 pm | #2 |
Re: Philips schematic
Hello Lee,
Are you sure that is the model number of your Philips radio ? Is it a Norelco brand set ? Would you post a pic of the radio please so we can find the European version of it. I have only one Philips radio that I know was sold in North America, the B5X04A here https://www.vintage-radio.net/forum/...7&d=1192736992 Is yours similar ? Howard Last edited by howard; 20th Feb 2009 at 4:33 pm. |
20th Feb 2009, 5:20 pm | #3 |
Howard that is it exactly I found another number with part of it missing
B5CL*A. Does this look better Lee |
20th Feb 2009, 6:08 pm | #4 |
Re: Philips CP 3691 schematic.
Hello Lee,
One or two Philips radios built in Switzerland had model numbers starting B5CH but usually the next two characters would be numbers and the last an 'A' or 'U'. The Philips model number is on a small oblong shaped label stuck onto the chassis and viewable through a slot cut in the rear cover. They do tend to come off or get damaged though .... What valves are fitted to the set, and what wavebands ? Any 'Bi-Ampli' or 'Stereo' labels on the dial or front? Norelco seem to have been active mainly in the late 1950s so it shouldn't be difficult to find your set. A pic of it would be useful. Howard Last edited by howard; 20th Feb 2009 at 6:19 pm. |
20th Feb 2009, 6:29 pm | #5 |
Howard I don't have a picture of it but here is the tube line up.
ECC83 ECH81 EBF89 EZ80 EL84 EL84 EM80 EYE TUBE It has 4 bands which are. MW SW-3 SW-1 SW-2 |
20th Feb 2009, 9:47 pm | #6 |
Hello Lee,
I haven't found even one Philips radio which resembles yours which is an odd one, as it is a Bi-Ampli set (2 x EL84) yet it's AM only, and all the Bi-Ampli sets I found have FM as well except for the B7X65A but that has slightly different valves. Try and find the model label. Howard |
21st Feb 2009, 1:21 am | #7 |
Howard here are some pictures I don't know if they will help or not.
Lee Last edited by Darren-UK; 21st Feb 2009 at 2:35 am. Reason: Enormous embedded images converted to thumbnails. |
21st Feb 2009, 2:16 pm | #8 |
Hello Lee,
Your Philips radio is indeed a model CP 3691 but I cannot find any trace of another example of it or any European market Philips set like it. It is very unusual, being an Philips AM only set housed in a Plano style case with the Bi-Ampli amplifier and two loudspeakers. At a guess I'd say it was built around 1960. In your quest to find a circuit diagram for it, I think your best bet is to ask about it on one of the Dutch radio websites, as the set was probably built in Holland. This site is the Dutch historical radio association. http://www.nvhr.nl I've found these Philips Plano radios to be very robust with first class quality components, the only parts worth checking/replacing are any black pitch capacitors. Howard |
21st Feb 2009, 2:47 pm | #9 |
Thanks Howard for all of your help.
Lee |
