Old 29th May 2019, 6:52 am   #1
Dwurban
Question Help Identifying Object: Likely from an old Military Radio
Hello everyone.
Hopefully this is the right place to post this, I've been asking all over the internet for help identifying this object I have pictures of and this place seems like a good place to ask, especially since someone recently recommended I try the avenue of UK Military Radio and not just USA Military.
I should mention that I'm not the first person to try identifying this object. Plenty of people have asked before me, but I think I am the most active searcher recently.
Well anyway, I've got have pictures of this unknown object that I, and several others, have been trying to identify for quite some time. We only know of two of them existing. Both were used as movie props, which is how we know about them and have pictures of them. But trying to find where they came from is a complete mystery. They were found sometime in the early to mid 1980s in California, likely at an electronic surplus yard like Apex Electronics. Both objects are made of aluminum and weigh 2 pounds. The only writing on it are the words VOICE, TONE, and RECEIVE (though RECEIVE has been sanded off on both objects). I've attached some pictures of the objects below, but for more detailed pics, as well as measurements of the object, check this link: ********************a/JpRw4tB
Our best guess is that it was from some sort of portable military radio. The ears on the sides would act as belt loops, and the VOICE and TONE were markers for a switch, similar to other military radios. Despite our best efforts, however, no one can find a clear, definitive answer as to what these things are and where they came from before being used as props.
Any help you all can provide is very much appreciated!
ID:	184106   Click image for larger version
ID:	184107   Click image for larger version
ID:	184108   Click image for larger version
ID:	184109   Click image for larger version
Dwurban is offline
Old 29th May 2019, 11:45 am   #2
G8BBZ
G8BBZ's Avatar
Default Re: Help Identifying Object: Likely from an old Military Radio
I think this is the casing for an optical transceiver. The attached photo shows a similar equipment used by the Wehrmacht in WW2- bigger but same basic idea. Lots more info on the website of LA6NCA.
cheers
Peter G8BBZ
Peter G8BBZ
G8BBZ is offline
Old 29th May 2019, 1:16 pm   #3
Graham G3ZVT
Graham G3ZVT's Avatar
That's what I think too. A modulated light transceiver / light-beam telephone, not unlike the ones a friend and myself built in the early 70s.
Graham.
G3ZVT
Graham G3ZVT is online now
Old 29th May 2019, 5:25 pm   #4
Dwurban
Thanks guys. This wouldn't be the first time these devices have come up in my search. But so far in what researching I've done I haven't found any proof that they're related, outside of the similar appearance. Not to say they're not, but if they are, it's not very well documented
Dwurban is offline
Old 29th May 2019, 5:38 pm   #5
Does the Voice/Tone shaft connect to anything in the right hand tube?
Old 29th May 2019, 6:55 pm   #6
Dwurban
It does not. The switch position doesn't connect to anything on the inside. Here's some more pics that can hopefully show that
ID:	184156   Click image for larger version
ID:	184157   Click image for larger version
ID:	184158   Click image for larger version
Dwurban is offline
Old 30th May 2019, 8:00 am   #7
The lugs towards the big holes end look like guides/retainers for a mounting strap.
The tone-voice quadrant and pivot pin seem to have no direct connection to the thing itself, so it must have been a convenient place to put a control for something not now there.
Machining marks show the main bores were cut with a right-size end mill in a straight plunge cut. Quicker than a boring mill or lathe job, but less precise.
I'm not sure it's even radio or electronic. Could just be a mounting bracket.
Radio Wrangler is online now
Old 30th May 2019, 10:33 am   #8
Do the two pin holes either side of the shaft go anywhere?
Old 30th May 2019, 6:09 pm   #9
Dwurban
Thanks for the observation, David!
I don't believe so, I think they were just used for holding screws. There's also a possibility that they weren't there originally and were drilled once the object was used as a prop, but take this with a grain of salt, we don't know for sure.
Dwurban is offline
Old 31st May 2019, 6:47 am   #10
Electronpusher0
Could it possibly an early microwave transmitter receiver using a Gunn diode. One large hole as transmit, the other receive and the centre chamber tthat goes between the two large holes providing the mixing function?
Peter
Electronpusher0 is offline
Old 31st May 2019, 7:18 am   #11
Dwurban
Hmm...this might actually be a solid lead. I haven't heard of a microwave transmitter in all my hours of searching, so I'll give it a go. Hopefully it'll lead to something, thanks for the tip!
Dwurban is offline
