12th Nov 2021, 3:32 pm | #1 |
OAP Speaker needs surgery
Iv'e read pliable glue and a coffee filter will patch her up, But eager to hear from the speaker experts..
Cheers Jay
Help!! I've been electrocuted by a glass thing that glows |
12th Nov 2021, 4:06 pm | #2 |
Re: OAP Speaker needs surgery
That's a bad tear. Use Tissue paper and PVA. Coffee filter paper may be too rigid.
Edward
Edward. |
12th Nov 2021, 4:07 pm | #3 |
PVA and kitchen roll or bits of newspaper is the usual solution. Lots of things will work.
12th Nov 2021, 4:09 pm | #4 |
Cigarette papers are good for this since they are all pre-cut to a handy size.
12th Nov 2021, 4:19 pm | #5 |
Some people like to dilute the PVA with water so it doesn't dry to a thick layer.
12th Nov 2021, 4:52 pm | #6 |
Cheers all,
PVA as in wood glue ? Jay
12th Nov 2021, 5:56 pm | #7 |
Yes. The white stuff which dries clear.
12th Nov 2021, 6:40 pm | #8 |
Cheers for the advice folks
Jay
12th Nov 2021, 6:53 pm | #9 |
12th Nov 2021, 7:06 pm | #10 | |
Jay
12th Nov 2021, 7:42 pm | #11 |
What about masking tape ?
12th Nov 2021, 8:02 pm | #12 |
I wouldn't use adhesive tape of any sort, as you never know how the adhesive will age. For a speaker you could use Micropore surgical tape then apply a coat of dilute PVA, but there isn't a lot of point.
12th Nov 2021, 8:07 pm | #13 | |
Daft question but never done it before Jay
12th Nov 2021, 9:39 pm | #14 |
wet the surface of the cone with the diluted PVA, lay the tissue paper on gently and dab with a brush wetted with the glue solution to get rid of air bubbles and to shape the repaired area. You may want to dampen some of the rest of the cone with solution so it dries uniformly.
Depending on access, you can put tissue on the back side as well. Let it dry and decide if you need another layer. David
12th Nov 2021, 9:46 pm | #15 | |
But just the info i was looking for Jay
14th Nov 2021, 9:56 am | #16 |
I've never done this either but actually had a need to do it today so this post was very useful. My speaker doesn't have a rip like the OPs speaker though, mine has been eaten by some insect, but is it the same process? just wet it and layer tissue paper? and should I cover a wider area as the insect may have weakened the material but it not be visible to the eye?
thanks Joe Last edited by hayerjoe; 14th Nov 2021 at 10:02 am. |
24th Nov 2021, 12:34 pm | #17 |
All done
24th Nov 2021, 2:27 pm | #18 |
Very nice. Does it sound OK, and not rattle? What about the immersive sense of depth, and pin-prick detailing which, though precise, is never harsh?
"The best dBs, come in 3s" - Woody Brown |
24th Nov 2021, 3:23 pm | #19 | |
24th Nov 2021, 5:03 pm | #20 |
I can add sod-all technical expertise to this site, so providing the occasional laugh is as good as it gets
