24th Oct 2021, 7:16 pm | #1 |
First Project Ever Ready Sky Leader. Poor performance on MW.
Hello to everyone. I’m new to the forum and to the hobby.
My first project is Sky Leader radio found in a boot sale. The refine and leather strap are in very good condition. I’ve given it a bit of a clean and fed the strap. The radio wasn’t working but after many hours on the internet doing some research I decided I was ready to give it a go. I cleaned all the moving parts with IPA and replaced the four large electrolytics made by Plessey. The radio has now come life with and seems decent on LW. I can only get one station and a low signal on MW. I did make a video but it wouldn’t upload. Any suggestions on what I should do next would be very welcome. Thanks Joe |
24th Oct 2021, 10:00 pm | #2 |
Re: First Project Ever Ready Sky Leader. Poor performance on MW.
Hi Joe, welcome to the Forum. You should find some useful tips here https://www.vintage-radio.com/repair...ltfinding.html . Best of luck with it. Jerry
24th Oct 2021, 11:21 pm | #3 |
Hi Joe, and welcome to the forum. Looks like you have found a nice set complete with the often missing strap. Ever Ready's first transistor set.
Sounds like you have cleaned the wave change switch. I would carefully check the wires from the rod aerial. The rod is not broken under the windings is it ? The service information is available top right of this page for £1.99. When referring to parts please say if it is "Trader" or Manufactures sheets you are using. Do you think someone has twiddled with the coils? I would not try adjusting them just look at this stage. John.
My favourite text message "I'll be there in five minutes, if not read again" |
25th Oct 2021, 12:50 am | #4 |
We had a Sky Leader when I was a kid, it replaced another transistor set that was stolen in a burglary, I think my dad clamed on the insurance. Fearing it might happen again he pasted a large label to the inside of the hinged lid saying "STOLEN FROM" and his name and address, not sure if that was the smartest thing to do.
Anyhow, I used to borrow the set when my dad wasn't around, and take it to my bedroom and listen to the local amateurs on Topband. The rather rudimentary tuning dial masked the slight adjustment I had made to the LO.
-- Graham. G3ZVT |
25th Oct 2021, 7:15 am | #5 |
Hi Joe, welcome to the forum. Go back to the switch contacts and confirm that there is no blackening and if necessary use a thin piece of card soaked in switch cleaner such as Servisol to gently rub in-between the moving and non-moving contacts (See picture).
When the M.W. button is depressed, make sure that the contacts are touching and if necessary gently adjust by bending. Hope this helps.
Regards, Ken. BVWS member |
25th Oct 2021, 11:56 am | #6 | ||
25th Oct 2021, 1:34 pm | #7 |
How do I tell if the rod is cracked?
Ferrite rods are prone to getting broken as they are brittle. Grasp each end of the rod and Very Gently twist in opposite direction. You should feel movement if it is broken under the coils. A broken rod can be glued and work perfectly. The wire from the coils are litz, made up from multiple strands. A break in one or more will have an effect on the signal received. I have had success with just leaving the set switched on for an hour in a set that has not been used for a long time. I expect this was due to the electrolytic capacitors reforming. John.
25th Oct 2021, 3:36 pm | #8 |
It's possible that the coils have just moved on the ferrite rod. Tune in a weak station and move the MW coil. There should be a very obvious peak in one position.
Looking at your photo, the ferrite rod doesn't look very healthy. Has a chunk broken off on the left hand side? |
25th Oct 2021, 4:35 pm | #9 |
Your rod appears to be 'bent' snapped. Picture attached of how it should look. Good luck with it. John.
25th Oct 2021, 5:11 pm | #10 | |
With my speaker wire out the window and earthed to some metal railings I can get radio 4 pretty well but there doesn’t seem to be anything else on mw. Long wave is good though. |
25th Oct 2021, 5:50 pm | #11 |
Super Glue works wonders on ferrite rods.
26th Oct 2021, 1:25 pm | #12 | |
1st Dec 2021, 8:03 pm | #13 |
It;s been a little while but I had time to finish the radio. The issue with MW not working well was actually LW and vice versa. My rotatational visualisation was mixed up. I decided to have a go at the LW alignment just using my ear as I don't have a sig gen. I tuned into R4 LW and adjusted the trimmer for max vol which made a big difference. I then turned the dial to just past 13 as per the manual where I could hear a single tone. I then adjusted this for max vol and then went back again
Result is loud and clear though a bit harsh across MW with decentish R4 on LW Thank you for all the comments and suggestions |
