| Vintage Audio (record players, hi-fi etc) Amplifiers, speakers, gramophones and other audio equipment. |
#1 |
I bought an RCA radio (FM & AM) from the USA many years ago when postage was not so expensive. It is complete with a 45RPM RCA player which sits on the top of the cabinet. These units were used in a large TV set which also had a 33rpm seperate player. It has all the original RCA valves and with its 6V6 GC output valves, it sounds (or did !!) very good. The other day I connected it up to a speaker and 110 volt supply but am getting quite a mains hum. I have checked all three sections 30uf/30uf/40uf of the reservoir/smoothing cap and all fine, if anything slightly higher than stated on the circuit. I have gone through the other caps and all seem to be ok, according to my cap tester.
With my scope there is a perfectly flat trace after the smoothing electrolytics and all through the set until the output from the output transformer where I get a typical mains voltage trace. Any thoughts how I can proceed ? When switched to radio , I can just pick up one station on AM and it is very faint and distorted. Mike. |
#2 |
You say a typical mains voltage trace on the output transformer, the output valve/socket could have a heater/cathode leak, if I understand your description correctly.
Frank |
#3 |
Just checked the output transformer and primary reads approx 510 ohms. Drawing states 530 ohms, so probably ok. Will have a check on the output valve bases. Circuit below, lucky I have the original factory service pamphlet, Model 7T143, RCA Victor (Television,radio,phonograph combinations.)
I was thinking of replacing C42 and C44 as a matter of course. |
#4 |
Top view of chassis.
#5 |
Panel lights are not working but valve heaters were on. Now wondering if there is a short somewhere between heater supply and chassis.
#6 |
This looks to have a nice specification. I noticed that you have previously been using this. Bear in mind your 45prpm turntable will run slow if the pulley has not been changed.
Edward. |
#7 |
Hi Edward,
I think the usual dodge is to slide a small piece of plastic tube over the motor spindle. These players don't have belts, the motor spindle just drives direct to the rubber idler wheel if my memory serves me correctly. I have as yet to restore the player, but at the moment, am concerned that possibly there are shorted turns on the main transformer heater winding. Hopefully not, but a quick check this morning looks like the heater terminals on the valve bases go direct to chassis. ( meter reading around 3 ohms but maybe bad connection. I did find a "dry joint " on one of the output valve bases where a wire had been carried through the terminal hole and on to another point,but I could not see a trace of solder, so "no joint" would be more accurate than dry joint.!! Mike. |
#8 | |
Is the 45 deck something like this? Alan |
#9 |
Hi Alan, yes exactly the same. I have around six of these varying in years. Some now working. Some I have changed the motor to 250 volt.
Mike. |
#10 |
The hum sage continues. I believe that somewhere from the panel lights to the mains transformer there is a leak to earth, so that is my next move. Valve heaters light up but panel lights don't, although i think they are on same winding.
Mike. |
#11 |
Got the scope out and thumbnail below shows trace from the point after smoothing/reservoir caps. Could a fault in the rectifier valve cause this ?
Mike. |
#12 |
Now got the panel lights working. A 3ohm wire wound resistor in line with the supply wire was causing them not to light. It was reading 3 ohms, but for some weird reason was not passing current.
Mike. |
#13 |
I don't think you've said (unless I've missed it) whether the hum is independent of the volume control setting or not. If it's regardless of the volume control then it's in and around the output stage and there could be internal leakage in the valve or surrounding circuit somewhere, but the more likely culprit would be the reservoir/smoothing capacitor/s, although you say you've already tested them. Personally, I think cap testers are usually a waste of time and proper diagnostic fault finding is the best way to 'test' for any faulty capacitors. Failing anything else showing up I would be temporarily tacking another electrolytic of the appropriate value and voltage rating across the main smoothing reservoir capacitor and noting whether this made any difference to the hum level or not.
#14 |
Definately agree with the above. I mean your unit must be mid-to-late 1950s to use Octal valves - thus making those caps 60+ years old.
Edward. |
#15 |
I am goung to change the output valve capacitors, the .001 1000volt ones on each valve anode. When I was checking them with my cap tester, I got the same type of hum through the speaker, powered I guess by the cap tester battery. They look pretty tired anyway, so when I can find some, I will change them as a matter of course. Most on Ebay are 630 volt. Maybe ok ?
Mike. |
#16 |
Farnel have a selection, unfortunately they are radial not axial but will do the job, not sure if there is a min order, if so try CPC-Farnel.
Frank |
#17 |
You need to replace the audio coupling capacitors C32 and C35. You also need to work out a way of measuring the output valve anode currents, I suggest you measure the voltage across each half of the output transformer primary and when switched off (and discharged ) measure the resistance of each half so we can calculate the anode currents.
The bias is created across R42 in the earth path, also measure this voltage. |
#18 |
Re. C42 and C44,(see circuit in early post.) is the rating of these caps critical or could they be .01 for example ? How are they calculated in the design. In the Hammond organ amplifiers, they are not present yet same output valves are used.
Mike. |
#19 |
C42/44 won’t be critical, but 10 times the value is rather a lot, I would stick to something with 10% of the stated value.
A 0.01 will likely reduce the upper audio frequencies. See what others say but that’s my take on the question.
Frank |
#20 |
When you say you tested the filter/reservoir capacitors, did you take them out of circuit and apply the rated voltage and check for leakage? Or as Techman says in post #13, tack another electrolytic across the main smoothing capacitor and note any change in hum. The metal cased main capacitor blocks of this era are much more reliable than other electrolytics in general, so can often be OK even if other components in the same unit are decrepit and beyond help.
If the coupling capacitors are wax types and ancient, they ought to be replaced as a matter of course to save expensive damage to valves and the output transformer. 0.01µF 1000V polypropylenes are available from Cricklewood here. As a reputable supplier they're likely to be more reliable than from a random eBay seller. |
