Old 18th Aug 2020, 6:47 pm   #21
Maarten
Default Re: Philips EL3541/15k transformer
This transformer doesn't have a soldered thermal fuse, rather it's held together by a small shackle of low melt metal. In the picture, the shackle is missing.
Maarten is offline
Old 18th Aug 2020, 7:42 pm   #22
DMcMahon
DMcMahon's Avatar
Hi Maarten,
That is interesting, so what is the black cylindrical object that looks like there is a wire coming out of it, on its right hand side and the wire then going into the body of the transformer in Post # 5 photo?
What is the spring/contact (copper) on the base/underside of the transformer ?
So what does the shackle hold together , do you have a photo showing the shackle fitted ?
DarthGrapes, so which part did you actually manage to solder repair ?
DMcMahon is offline
Old 18th Aug 2020, 7:45 pm   #23
3rd photo, Post#12:
https://www.vintage-radio.net/forum/...d.php?t=137366
Old 19th Aug 2020, 8:23 pm   #24
DarthGrapes
Originally Posted by DMcMahon View Post
Hi Maarten,
That is interesting! I just soldered the two points that are held by the shackle. There was no sign of the shackle in the machine and it seems to be doing the trick.
DarthGrapes is offline
Old 19th Aug 2020, 8:39 pm   #25
DMcMahon
DMcMahon's Avatar
Originally Posted by ms660 View Post
Than you Lawrence, have never seen or heard of these thermal links before.
DMcMahon is offline
