Old 5th Jun 2020, 3:22 pm   #1
carlos10
carlos10's Avatar
Default Howes DFD4/5 counter
hi,
anyone familiar with this counters
it has a matrix board howes pmb4
there is a A and b swith on the front a = usb,lsb,am&fm
b = usb,lsb,am&fm
a is not selectable by the switch, only b
there is also a small dfd4 pcb mounted
is the counter dfd4 or5.......
picture atached
regards carlos
carlos10 is offline
Old 5th Jun 2020, 3:26 pm   #2
AC/HL
AC/HL's Avatar
Default Re: Howes DFD4/5 counter
Some information here: http://www.snowbird.plus.com/electronics/index.shtml
AC/HL is offline
Old 5th Jun 2020, 4:33 pm   #3
John KC0G
This kit was originally made by C.M. Howes Communications. It was last sold no later than early 2004. You have the DFD4 (four digit) counter with the PMB4 programmable matrix board for 6 programmable offsets. The DFD4 just had one. The DFD5 counter had a 5-digit display but without a programmable offset,
Please see these two links:
https://web.archive.org/web/20000523...-html/DFD4.htm
https://web.archive.org/web/19991109...tinfo/DFD4.pdf
Then you should ask the GQRP club for copies of the kit instructions for both the DFD4 and PMB4. See http://www.gqrp.com/howes.htm
HTH and 73 John
John KC0G is offline
Old 5th Jun 2020, 5:16 pm   #4
carlos10
carlos10's Avatar
thanks to all who responded carlos
carlos10 is offline
Old 5th Jun 2020, 6:51 pm   #5
carlos10
carlos10's Avatar
hi, was the bcd programmable matrix board dfd4 pmb4 factory assembled..
nothing in any parts list manual......
carlos10 is offline
Old 6th Jun 2020, 12:35 am   #6
Granitehill
I have a DFD4/PMB4 which I use with an Eddystone 680X and an Eddystone 1830.
The board was not factory assembled - the builder programmes it by fitting the appropriate diodes. I have the manual for the PMB4 which explains all (The DFD4 manual also shows the arrangement of program diodes in page 6 of the assembly instructions, but for single offset only).
I can scan this in a day or so - I have your email as shown on QRZ.COM. PM me if you would like more info.
John G4FDD
G-QRP 431
Granitehill is offline
Old 6th Jun 2020, 10:16 am   #7
carlos10
carlos10's Avatar
hi john, please mail me the info, much apreciated,time is not important hi
regards carlos
carlos10 is offline
