15th Mar 2023, 4:24 pm | #1 |
New Project: Ferguson 3026 restoration
Hi All,
I recently acquired a Ferguson 3026. It's my first project restoring a record player - I've never even owned one before and know almost nothing about them yet, but my wife has some records she's not been able to play for years so I thought why not give it a go. Managed to pick this one up at <£40. Anyway, pre-amble over, I've just got a couple of questions before I get stuck into it: - 1. Does anyone have any user manuals, circuit diagrams or schematics they could send me, or know where I could get some 2. We've tested on a couple of records, and while it produces sound the output level is really low even with the volume control turned up fully. I've had it suggested variously to change the stylus, the cartridge, or both, or to check the capacitors and leave the cartridge alone. Where would you all suggest I start? 3. There is also a random cylindrical piece of what seems to be stainless steel about 5cm long and 5-7mm in diameter clipped into a bracket on the underside of the lid. What is this for? On the plus side, the autochanger works and the music quality is decent aside from the volume being low. Cosmetically, in pretty decent condition for its age. Any help and guidance provided is greatly appreciated |
15th Mar 2023, 4:48 pm | #2 |
Re: New Project: Ferguson 3026 restoration
The cylindrical thing is the short spindle for when you want to play one record manually and not use the autochanger.
A new stylus will not improve the volume, but a new cartridge would. To see if this is necessary, and assuming that it still has the original Sonotone 9TA cartridge fitted, turn the volume up to max, and touch each of the wires on the back of the cartridge in turn with a small screwdriver. One of them should produce a loud hum, which will prove that the amplifier is ok, and a cartridge is needed, No hum, and the amp will require attention. Barry |
15th Mar 2023, 5:06 pm | #3 | |
15th Mar 2023, 5:09 pm | #4 | |
https://www.service-data.com/section.php/2619/1/3026 Any good? As always, worth checking the link at the top of this page first |
15th Mar 2023, 5:30 pm | #5 | ||
15th Mar 2023, 8:38 pm | #6 |
Sorry if my reply led you astray, I was thinking of a different model of record player., but the process is the same for any cartridge. The connecting sockets on the ends of the wires are hidden in clear plastic shields, so you need to very carefully and gently pull them off the cartridge and touch the screwdriver on the ends of the sockets.
15th Mar 2023, 11:01 pm | #7 |
These are capable of nice sound.
Do the 'buzz test' ad let us know. You might be able to get away with poking a small jewellers's screwdriver (flat blade) at the pins where they meet the cartridge body if there's a bit of exposed metal. This would save you disconnecting them. If you do disconnect them make a note of what colour goes where. I recently had a BSR c1 cartridge which was going intermittent on one channel, so it is entirely possible that yours is faulty. Some of us on here can repair these older carts but it is often easier to buy a new one like the SC12H. Anyway post back and we can take it from there.
Regards, Ben. |
16th Mar 2023, 5:34 pm | #8 |
Hi Ben,
Did the buzz test - nil heard. Though in the process I noticed that one of the wires had been badly soldered, and another the collector was very loose. That being said, while making sure everything was connecting properly and volume turned up to full, no noise from the speakers. I guess I need to look at repairing or replacing those wires first and see if that makes a difference. Will let you all know how I get on. |
16th Mar 2023, 8:56 pm | #9 |
Reckon I may have found the problem... One large black broken capacitor on the board
19th Mar 2023, 11:51 am | #10 |
I would treat all of those large black capacitors as problems!
20th Mar 2023, 12:36 pm | #11 | |
All - thanks for all your help and input with this project. It's been really useful and appreciated. |
22nd Mar 2023, 10:22 am | #12 |
Update:
Broken capacitor and resistor replaced & cartridge wire re-attached. Now working a lot better. Still not perfect but a significant improvement in output volume. The project continues! |
22nd Mar 2023, 10:30 am | #13 |
If I were you I would replace all those black capacitors. Don't use the player until this is done.
Regards, Ben. |
22nd Mar 2023, 10:32 am | #14 |
30th Mar 2023, 9:43 am | #15 |
PROJECT UPDATE:
250uf capacitor (C11 on the circuit diagram) replaced last night. *Massive* improvement in volume output. Before, needed to put the volume control to max (10) to get any decent noise out; now have it on 3 and it's more than loud enough. Next problem: The tonearm doesn't seem to be applying sufficient tracking weight - in order to get good, consistent sound and levels, requires 2 x 2p pence pieces on the headshell. Going to give the records a good cleaning to ensure it's not just dust causing the problems before I take next steps. |
30th Mar 2023, 10:43 am | #16 |
There's no way that's just dust causing tracking problems. If I recall, these players used a BSR C141 deck with a c1 cartridge. I have had these carts go intermittent due to tarnished internals, pressure brings the sound back. Maybe that's what is happening here. if so replace with SC11 /12.
Check also condition of stylus (likely ST3), try both tips, if the cart is good then you can replace it (you can also use ST15 if you don't plan to play 78s).
Regards, Ben. |
30th Mar 2023, 4:16 pm | #17 |
Cheers, Ben - thanks for the feedback. Currently looking on gettheneedle.co.uk at a BSR SC11M Ceramic Cartridge with LP/33/45 only stylus for about £40.
Do you think it at all likely that the problem could be with whatever part it is that controls the tonearm pressure? Want to eliminate that as a possibility before I fork out ££ |
30th Mar 2023, 4:27 pm | #18 |
The deck may need stripping down, cleaning and relubricating if this hasn't been done already. There's a lot of info about this in the sticky threads at the top of this section.
If the cartridge is working well with plenty of volume then you're unlikely to see much benefit by changing it. A new stylus is a good idea if the condition of the existing one is unknown though. Don't try to cure tracking problems by piling 2p pieces on top of the cartridge if it's jumping and skipping - that's very likely to wreck your records. The tracking weight should be around 5g if you have a way of measuring it. |
30th Mar 2023, 4:32 pm | #19 |
31st Mar 2023, 11:40 am | #20 |
It's very bad pratice to add weight like that to your tone arm. I've tried searching but can't find a Ferguson 2026. What type of deck is fitted? It's likely to be a BSR or a Garrard. A photo will help, then we can advise you as to how to correctly set the tracking weight.
Edward. |
