26th Oct 2018, 9:33 am | #1 |
Hunts CRB Bridge - Annotated circuit
There was a recent request in a now closed wanted thread, for a copy of the Hunts CRB and a copy was duly uploaded. However, for some odd reason, though Hunts included the circuit in the manual, rather unhelpfully, it had no markings as to the values of resistors and capacitors.
Some time ago I came across a copy of the circuit on which hand-written values had been added, so I cleaned the circuit up a bit, removing the handwriting and added printed values. I don't have a CRB so can't confirm whether the values are correct, but for what it's worth, I've attached the circuit that I annotated, which might be of help to someone.
26th Oct 2018, 10:09 am | #2 |
Re: Hunts CRB Bridge - Annotated circuit
Ron Bryan did a full schematic for the Hunts CRB in Post#1 in the link below showing the rectifier connected the correct way round (in modern terms) complete with some voltage measurements and all the component values:
https://www.vintage-radio.net/forum/...d.php?t=141358 Lawrence. |
26th Oct 2018, 2:04 pm | #3 | |
David. BVWS Member. G-QRP Club member 1339. Last edited by David G4EBT; 26th Oct 2018 at 2:16 pm. |
