Old 13th Nov 2017, 10:04 am   #1
paul161201
Default Vintage GPO 1970 Telephone No 746 Pax 68/1
I purchase a GPO 1970 telephone from Ebay which had been converted. The phone worked fine for about a month, but now not working. I cant ring out or receive calls. When i pick up the receiver it makes allot of white noise but when i start dialling a number the noise disappears but the noise come back as soon as i have finish dialling.
I used my mobile phone to test if i could receive incoming calls. The phone didn't ring, But when i picked up the handset/receiver i could hear a ringing tone as if your waiting for a call to be answered. Also when i replace the receiver down it doesn't make that bell sound any more
Any ideas what the problem could be?
paul161201 is offline
Old 13th Nov 2017, 1:19 pm   #2
russell_w_b
russell_w_b's Avatar
Default Re: Vintage GPO 1970 Telephone No 746 Pax 68/1
Dodgy broadband filter?
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
Old 13th Nov 2017, 1:28 pm   #3
paul161201
When i disconnect my modem i don,t get the white noise. but everything else the same phone still not working
Old 13th Nov 2017, 2:46 pm   #4
Euros1951
As Russell says. Remove the Broadband filter (and the router) and see if you get Dial Tone. If not, then check continuity of the telephone cord to the socket. If that fails , check for any loose screws and terminations in the telephone, and check for any dry soldered joints.
Euros1951 is offline
Old 14th Nov 2017, 8:57 am   #5
paul161201
I have disconnect everything all i have in the socket is the phone
i do get a dial tone
I have checked for dry joints and loose connections all seem fine will check cord later today.
Someone told me it could be the micro switch is this likely?
Old 14th Nov 2017, 9:46 am   #6
paul161201
Checked continuity in cord from phone to socket which is fine
Old 14th Nov 2017, 9:47 am   #7
Check the continuity of the bell coils from the plug.
Station X is online now
Old 16th Nov 2017, 5:23 pm   #8
paul161201
I tried my phone on a different line and the phone worked
Must be a problem with the line
Old 16th Nov 2017, 8:06 pm   #9
Nickthedentist
Nickthedentist's Avatar
I suppose it could be but it's more likely to be a fault with your master socket I would have thought.
Nickthedentist is online now
