31st Aug 2017, 2:20 pm | #1 |
Stereo Console Bergamo GB (Grundig) - TX cooked
Hi folks,
This is a really lovely set - certainly in terms of the build quality of the electronics, from what I can see -not so fussed about the cabinet - but is currently kaput with a blown main transformer. The secondary is cooked and bubbles even off load, there is another winding, whose voltage I don't know yet - likely the the heaters. ECC85, ECH81, EAF801, ECC83 and wonderful ELL80 - a double output-pentode in one envelope for push-pull use - are all intact. Anyone can source a cct diagram for me please? I think in view of the age of the thing, the bridge rectifier was probably SC for some reason. I will check later. There are no obvious catastrophic failures of any component. My goal is to find out what the other secondary winding is first, before hunting for a replacement transformer. BUt if anyone has prior experience with this beauty, be interested to know what aere the possible fault conditions leading to a cooked main transformer. Thank you
Al |
31st Aug 2017, 2:37 pm | #2 |
Re: Stereo Console Bergamo GB (Grundig) - TX cooked
Have you tried Radiomuseum?
You would be better to get the original TX rewound. Mike Barker or Ed Dining can sort that for you. |
31st Aug 2017, 2:42 pm | #3 |
Bergamo was a generic name for a range of radiograms made by Grundig over a number of years. The last ones were transistor.
Could this be yours.... http://www.radiomuseum.org/r/grundig..._st_cs200.html If it is, very nice. Have a very soft spot for Grundig audio kit. Used to love to go to the showroom in Orchard Street, just off Oxford Street. Good luck with it, Peter |
31st Aug 2017, 6:59 pm | #4 |
Hey, Peter, that looks like the one! Thank you !
Amazing quality! Maurice , good idea. It first I'd like to establish if there is any fault downstream before making such an investment ...
Al |
31st Aug 2017, 9:07 pm | #5 |
Hi Al, always pays to use an HT fuse on these sets, either in the feed to the bridge or in the CT if it is full wave. It's a mod I do on most sets .
Transformer should rewind OK. Ed |
31st Aug 2017, 9:58 pm | #6 |
Cheers, Ed!good advice !! I'll PM you re the rewind, if it looks like there are no other faults downstream ...
Al |
