Reply
Old 19th Sep 2023, 2:28 pm   #1
EdGizzard
Default Transistor Equivalents
Hi All,
Can't find any info on this Transistor. See attached. 109A
Any thoughts of equivalents or where buy?
Thanks Guys
EdGizzard is offline   Reply With Quote
Old 19th Sep 2023, 2:35 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Transistor Equivalents
That looks like a house code. Are the other transistors on the board the same? If so, remove another one and do some basic checks on it. You should be able to decide between NPN/PNP and the gain band that way.
If it's NPN, one of the standard jellybeans will probably be OK - 2N2222, 2N3904, BC547, whatever you have handy.
paulsherwin is online now   Reply With Quote
Old 19th Sep 2023, 2:46 pm   #3
Jez1234
There is a J109 FET but I don't think there is a version with an A suffix. It could well be a house code.
Jez1234 is offline   Reply With Quote
Old 19th Sep 2023, 2:49 pm   #4
EdGizzard
Thanks so much Paul,
Looking at CD they all (4 of this type) appear to be PNP. Unfortunately it doesn't give the transistor type. Just a symbol.
Old 19th Sep 2023, 2:49 pm   #5
paulsherwin
The leads are marked EBC which strongly suggests bipolar, though it's not a guarantee of course.
If it's PNP then just try an appropriate jellybean - 2N3906, BC557, BC327 etc. It's unlikely to be critical.
What is the PCB doing?
Old 19th Sep 2023, 2:50 pm   #6
Station X
Station X's Avatar
What's it installed in?
Graham. Forum Moderator
Station X is offline   Reply With Quote
Old 19th Sep 2023, 3:00 pm   #7
G6Tanuki
G6Tanuki's Avatar
109A could be BC109A??
Not sure about the manufacturer but in the past it was not unusual for manufacturers to use their initials in place of parts of the type numbers, I have a number of 2N3055 here marked RCA3055 for example.
I played a blank tape at full volume. The mime-artiste who lives next door complained.
Old 19th Sep 2023, 3:16 pm   #8
EdGizzard
Thanks All,
Its generates the bass in an electric organ. This PCB does Vibrato also but that's a different part on the board. I'm Feeling NPN the more I look at it. There are a few variations of these organs. My CD is for another variation so can only be used as a guide really. Thanks Guys
Old 19th Sep 2023, 3:26 pm   #9
paulsherwin
It's very unusual for designers to use predominantly PNP transistors as these used to cost more - not sure if that's still the case.
I guess it could be a BC109A in a TO92 package, though that would also be unusual.
Old 19th Sep 2023, 3:29 pm   #10
Aub
Aub's Avatar
That M looks a bit like a smudged Motorola symbol?
Aub
Life's a long song, but the tune ends too soon for us all.
Aub is offline   Reply With Quote
Old 19th Sep 2023, 3:32 pm   #11
paulsherwin
Motorola did use house codes a lot at one time.
Old 19th Sep 2023, 4:59 pm   #12
Jez1234
Ah yes well spotted!
Old 19th Sep 2023, 7:02 pm   #13
Maarten
Often the most important clue is, the brand and type of the equipment (organ).
Motorola, might be a BC109A equivalent seems the best that can be done without context.
Maarten is offline   Reply With Quote
Old 19th Sep 2023, 7:36 pm   #14
Sideband
Sideband's Avatar
Aub
I was going to suggest the same....certainly looks Motorola-ish.
Sideband is offline   Reply With Quote
Old 22nd Sep 2023, 10:17 am   #15
llama
llama's Avatar
Is the equipment faulty (in that area)?
If working, or a similar board is working, it could be worth noting its voltages for future reference, to help identify the part, or to fault-find if/when it stops working.
Graham
Half my stuff is junk - trouble is, I don't know which half!
llama is offline   Reply With Quote
Old 23rd Sep 2023, 10:26 am   #16
Maarten
Besides the brand and type of the organ, other context that might contain clues, are the country it was made in (Italy? UK?) and numbers on other transistors (Motorola but also other brands if used) to establish if there's a system to it.
Old 23rd Sep 2023, 3:43 pm   #17
Richardgr
I was looking fr some equivalents recently and found this useful old dcument from 1981 ...
Bernards bp85-international-transistor-equivalents-guide.pdf
There was one hit containing 109a, a National Semiconductor device.
Richardgr is offline   Reply With Quote
Old 26th Sep 2023, 1:38 am   #18
Oldmadham
Manufacturers like to reduce their inventories and often use the same transistor in critical & non-critical positions.
If one of the same type is doing some "grunt" work like turning on an indicator LED, steal that one for the critical spot, & replace the "LED driver" with a "jelly bean" component.
Oldmadham is offline   Reply With Quote
Reply
