Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps. |
#1 |
Hi folks,
Just got myself a pair of vintage 70's Erres (Philips) headphones, which work great with my vintage record player, but I really want to use them with my guitar amp, meaning I need to find a way to convert the 5-Pin DIN "Domino" connector to 3.5mm. I know how to handle a soldering iron, but I'm not sure how to wire the DIN connector to 3.5mm, nor am I sure if I can even directly connect them at all without an amp in the circuit. Can anyone help me figure this out? Thanks in advance, Guitarman0512 |
#2 |
Is this the sort of thing you need? https://www.ebay.co.uk/itm/203786618176
Similar adaptors are probably available from the NL eBay site. |
#3 |
When you say "domino" five-pin, do you actually mean with the pins arranged like the number five on a set of dominoes, rather than the semi-circle as shown in Paul's link?
#4 |
The photo attachment at Post 1 of this linked Thread shows an example of a chassis mounted 5 pin Domino connector, which as Dave above says is different from a standard 180 degrees 5 pin DIN.
https://www.google.com/url?client=in...WCv9bSqeVdPE05 David |
#5 |
Ah, right.
I do remember Philips and Sennheiser using those on headphones in the 70s. |
#6 |
Also Braun on their R2Rs.
David |
#7 |
If you are not worried about it losing its authenticy, you could remove the Domino plug connector off the headphones cable and replace it with a 3.5mm stereo audio jack plug, most likely will be a 2 core screened cable so only 3 connections.
Of course it then would not work with your vintage record player. David Edit update - This assumes the guitar connection you reference is a headphones stereo output and that the output impedance of the guitar amp is similar to the headphones impedance. Last edited by DMcMahon; 18th Sep 2023 at 2:15 pm. Reason: Update |
#8 |
I've done several adaptors like this with a foot or so of cable for interconnecting old headphones and various equipment with DIN, 1/4", 3.5mm plugs etc.
I've attached some documents with common pin-outs. If you have a guitar amplifier with a headphone jack, then wire up the 3.5mm plug as normal. I assume it's mono, being guitar, so you'll need to tie left and right together. Probably with a wire link at the DIN socket end rather than the 3.5mm plug as there'll be a little more room. |
#9 |
Thanks everyone! I think I can figure something out now. I'm not quite sure about the impedance of my amp, nor the headphones, but I'll just order the parts and find out myself I guess.
#10 |
What a fantastic document, might be worth adding that to the 'reviving your old tape recorder' thread for future reference.
Regards, Ben. |
#11 |
Ben, where is the 'reviving your old tape recorder' thread ?
David |
#12 |
My mistake, it was the 'transferring old tapes to PC' thread that I meant, it has information about DIN connections in it. https://www.vintage-radio.net/forum/...d.php?t=103289
Regards, Ben. |
#13 | |
![]() Quote:
If you have a DMM you could measure the DC resistance of the headphones, the value of which will be similar to the AC impedance, i.e. if you measure 6 Ohms then the headphones nominal impedance will probably be 8 Ohms. If you can find a spec sheet for the guitar amp then that should state the recommended headphones impedance. David |
#14 | |
![]() Quote:
