#1 |
This rectifier is in a radio I'm currently working on. The schematic calls for a 5Z4. The only markings I can find are on the bottom and have no reference in Valve museum.
I believe someone has fitted it as a replacement at some point and I don't want to power the radio up even on a dim bulb unless I know it is a viable alternative to the 5Z4. The base was very loose when I got it and had been sellotaped to the glass. Needless to say, the Sellotape had perished and was baked on to the glass. I've removed as much as I can and super glue came to the rescue. Thank you for your insights. |
#3 |
#4 |
5U4G. Directly heated with the correct missing pins for this type. Note that it's directly heated and has a 3A filament current, so not a correct replacement for a 5Z4.
Leon. |
#5 |
The GZ30 has exactly the same missing pins, so identification this way is probably not possible. Measuring the heater current would be useful, though I think a few more valves have this pinout and some may have the same heater current.
#6 |
The base reminds me of Cossor, GEC, Marconi.
Lawrence. |
#7 | |
![]() Quote:
John.
My favourite text message "I'll be there in five minutes, if not read again" |
#8 |
The rectifier image in the first post is of a directly heated type in a large "G" size envelope. This must rule out the GZ30/5Z4 which is indirectly heated. The 5U4 matches the image.
Leon. |
