Reply
Old 9th Sep 2023, 5:51 pm   #21
Paul_RK
Paul_RK's Avatar
Default Re: Premier 3 Valve TRF
Except the transmitter will have gone off air for ever before the next home test series...
Paul
Paul_RK is offline   Reply With Quote
Old 10th Sep 2023, 12:26 pm   #22
Clive G7LUC
Just to let you all know that the Premier TRF s working very well. It had probably been taken out of service still in running order. When I got the set it was stuffed full of probably carpet fluff. I blew this out with an airline and fitted a new mains lead. I also disconnected the frame aerial and installed an ordinary aerial terminal.( I plan to research frame aerials.)
So standing at a safe distance and wearing rubber gloves and safety goggles I switched it on and it worked fine. Good sensitivity and plenty of volume. There are only two medium wave stations audible now during the daytime in Liverpool so I'll be looking forward to checking the band again after darkness.The third knob made the sound a bit louder but doesn't seem to do much. Maybe the builder just deleted the wave change and added a reaction control instead.
This is only the second TRF set that I have had, the first being a HAC single valve kit which had worked very well on the shortwave bands. What impressed me with the Premier was how sensitive it was and how good the audio was, clear and as loud as you wanted it. But I later realised what was really good, namely the complete lack of "squeals and whines", the unwanted products of superhets with their powerful on board oscillators. So now I'm a TRF fan!
Clive G7LUC is offline   Reply With Quote
Old 10th Sep 2023, 2:29 pm   #23
Sideband
Sideband's Avatar
Ummm what sort of superhets have you been listening to? A properly aligned superhet will not whistle or whine....if it does, there is something else wrong!
Sideband is offline   Reply With Quote
Old 10th Sep 2023, 6:05 pm   #24
FERNSEH
FERNSEH's Avatar
Originally Posted by llama View Post
1500 long wave was actually 200kHz and only changed to 198 when all channels were modified to be multiples of 9. Someone here will remember the date of that change!
Graham
An article appeared the April 1989 EBU Review (Technical) describing the conversion of the BBC R4 Droitwich transmitter from 200Khz to 198Khz.
Title: "LF broadcast transmission facilities in the United Kingdom"
Subject matter is worthy of discussion in a separate topic.
DFWB.
ID:	284766   Click image for larger version
FERNSEH is online now   Reply With Quote
Reply
