Reply
Old 27th Jun 2023, 8:20 am   #1
Beardyman
Beardyman's Avatar
Default HMV ls7
This extension speaker came up a lot better than I was expecting.
The cloth on the front & back was absolutely rotten & beyond any help but I did find something similar in one of our local charity shops.
The unit is quite well made with the speaker mounted on a removeable baffle board, all the mounting screws go into captive nuts set into the wood including the back panel.
The back panel was held on with two wood screws, I changed the screws for modern ones for the time being until I can find some age related parts.
The speaker still had it's original dust cloth around it but that was disintegrating too, my better half volunteered to make a new one, result!
Removal of the speaker showed a cone & suspension in very good overall condition, no rubbing on the center pole either.
Voice coil reads around the 3-4 ohm mark.
At some point in time the matching transformer had been removed.
I haven't completed a project for quite a while so this was a nice gentle re-introduction!
I've always wanted a cathedral shaped woody in my collection but the radios are a bit beyond my pocket money!
This was a good compromise.
Despite much hunting round t'interweb I can't come up with even so much as an advert for it.
It is, at the moment, hooked up to my Defiant MSH902, sounds good too.
ID:	280367   Click image for larger version
ID:	280368   Click image for larger version
The difference between stupidity and genius is that genius has its limits. (Einstein)
Beardyman is offline   Reply With Quote
Old 27th Jun 2023, 9:09 am   #2
vinrads
Default Re: Hmv ls7
That looks superb I think the cloth is in keeping very well done . Mick.
vinrads is offline   Reply With Quote
Old 27th Jun 2023, 10:18 pm   #3
McMurdo
McMurdo's Avatar
Default Re: HMV ls7
I assume you repolished the cabinet, how did you do it?
Kevin
McMurdo is offline   Reply With Quote
Old 28th Jun 2023, 3:39 pm   #4
Beardyman
Beardyman's Avatar
Default Re: HMV ls7
McMurdo,
The original varnish had gone black with age as is the case with something of this age.
That was stripped off using Acetone & 0000 wire wool, a mucky smelly task.
As the old varnish liquifies it tends to fill the grain of the veneer nicely.
Let everything dry out for a few days then a light rub over with clean wire wool.
Two coats of Danish Oil leaving 48 hours between coats & voila, job done.
My cabinet finishing skills are, at best, amateur beginner but this one turned out ok.
Old 29th Jun 2023, 8:07 am   #5
JonSnell
JonSnell's Avatar
Default Re: HMV ls7
Very nice indeed. Good job!
Valve equipment repairs since 1968 https://jonsnell.co.uk
JonSnell is offline   Reply With Quote
Old 30th Jun 2023, 12:44 pm   #6
Beardyman
Beardyman's Avatar
Default Re: HMV ls7
Just for comparison sake, here's the thread I posted when I first got this item home, the phone camera makes the finish look far lighter than it was!
https://www.vintage-radio.net/forum/...d.php?t=200697
Old 2nd Jul 2023, 4:14 pm   #7
Phil G4SPZ
Phil G4SPZ's Avatar
Default Re: HMV ls7
A fine-looking job!
I have re-finished several sets using Danish Oil and I like the finish it produces, plus it’s relatively easy to apply and gives good results. One tip I tried and which gave an even higher gloss finish is, when fully hard (2-3 weeks) to polish the surface with something like Liberon Burnishing Cream.
Phil
“The place where optimism most flourishes is the lunatic asylum” - Henry Havelock Ellis
Phil G4SPZ is online now   Reply With Quote
Reply
