#1 |
The Pye/Philips Shaver mic is a design-classic from the 70s; we had loads of these back in my days running a PMR business. [macho taxi-drivers used to call them the 'Ladyshave' after one of Philips's more popular products].
Got one at the West of England rally last week, and wanted to hook it up to my Ten-Tec Corsair-II acquired from a fellow forumeer. The Corsair's designers helpfully provide a pin on the mic-socket that is intended for electret-mic bias, great - the Shaver needs electet bias too! The shaver's PTT works by taking a 10V feed [which supplies the electret] and applying this back to the radio when the PTT is pressed. The Corsair needs a classic 'ground to transmit' PTT feed. A quick re-work - inside the shaver's case is a small PCB that contains the electret bias-components and a treble-cut network. I removed the white wire from the PCB to the PTT switch, and replaced this with a wire linking the PTT switch's now-redundant terminal to the green/screen ground terminal. Basically, disconnect the wire from pin 8 and connect it to pin 2. So now at the radio-end of the curly-coil wire we have: Red: audio output Green/screening-braid: ground White: electret bias-voltage Red: audio output Blue: PTT line, ground-to-transmit. Put it all back together - it works! And to celebrate I worked a station in Bonaire on 28MHz.
TURN IT UP! [I can't hear the Guitar] - TMBG. Last edited by G6Tanuki; 18th Jun 2023 at 4:04 pm. |
