Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > General Vintage Technology > Where To Get Sets and Parts
Where To Get Sets and Parts For discussions about swapmeets, rallies, NVCF and BVWS, car boot sales, antique and charity shops, dealers, newspaper adverts, the local tip and just about any other source of equipment (other than eBay).
Reply
Old 9th Sep 2022, 9:20 am   #1
samjmann
samjmann's Avatar
Default Cost of Freezer Spray.
I haven't looked at the cost of freezer in a long time, but I was shocked when I saw RS selling a 400mL can for around £20:00.
The non-flammable freezer is more expensive than the flammable type which is typically used for freezing pipes etc.
Plastikote do a non-flammable 500mL can which I've seen for as low as £9.00. This is intended for electronic use. Years ago I do remember some freezer reacting with solder flux and causing it to bubble. The boards did look messy afterwards.
The Ambersil and Servisol brands are all around the same price as RS's own PRO range. Just makes me wonder why the Plastikote is so much cheaper...
SJM.
It's never been right since we've had it...
samjmann is offline   Reply With Quote
Old 9th Sep 2022, 9:54 am   #2
Lloyd 1985
Lloyd 1985's Avatar
Default Re: Cost of Freezer Spray.
Isn’t there a cheaper one that’s aimed at removing chewing gum?
Regards
Lloyd
Lloyd 1985 is offline   Reply With Quote
Old 9th Sep 2022, 10:16 am   #3
samjmann
samjmann's Avatar
Thanks Lloyd, yes I've seen that. In fact Plastikote do their version of that too. I don't to go wafting freezer onto a pcb and leave some nasty residue behind afterwards.
Regards SJM.
Old 9th Sep 2022, 11:16 am   #4
Keith956
Keith956's Avatar
£5 a can on Amazon:
https://www.amazon.co.uk/AAB-Cooling...ddba1bf6a&th=1
Keith956 is offline   Reply With Quote
Old 9th Sep 2022, 1:08 pm   #5
Craig Sawyers
Craig Sawyers's Avatar
Cheap, but this is the inflammable version. So if there is anything hot nearby (like a valve, or other hot part) it could get a little exciting.
But I like the suggestion on that Amazon product that you can use it to free up stuck or rusted screws.
Craig
Doomed for a certain term to walk the night
Craig Sawyers is offline   Reply With Quote
Old 9th Sep 2022, 2:04 pm   #6
Cruisin Marine
What about those "Air Duster" sprays inverted, they only cost just about a pound a can in the "pound shops".
Just tried one, they are cold enough when used upside down, and no damage to solder on a scrap board.
Cruisin Marine is offline   Reply With Quote
Old 9th Sep 2022, 3:53 pm   #7
samjmann
samjmann's Avatar
Have purchased the non-flammable Electronic Motip freezer spray.
Worked out at £6.00 per can when buying 6. Motip are based in the Netherlands, best known as the Plastikote brand in the UK.
Will post again with findings! SJM.
Old 9th Sep 2022, 4:13 pm   #8
vidjoman
Some years ago the price doubled on Freezer spray due to the previous use of 'greenhouse' gas. The 'newer' gas is less of a problem, just much more expensive.
I recall it was about a fiver a large can which jumped to £9.99 for a smaller can.
vidjoman is offline   Reply With Quote
Old 9th Sep 2022, 6:36 pm   #9
buggies
buggies's Avatar
Google ‘poop freeze’ (for dogs).
I bought a 150mL can from B&M for £1.99 last year - have not looked recently.
George
buggies is offline   Reply With Quote
Old 10th Sep 2022, 12:01 pm   #10
Welsh Anorak
Welsh Anorak's Avatar
Ditto - not as effective IMHO, and leaves a bit of a residue,but a lot cheaper. I think mine came from Home Bargains.
Glyn
www.gdelectronics.wales
Welsh Anorak is offline   Reply With Quote
Old 13th Sep 2022, 11:38 am   #11
Paul Stenning
Administrator
Paul Stenning's Avatar
I haven't tried this, but perhaps a layer of cling film over the suspect component and surrounding area would avoid the need to clean up any residue while still having a good cooling effect? Assuming of course that nothing is getting hot enough to melt cling film.
Paul Stenning
Forum Admin/Owner and BVWS Webmaster
Paul Stenning is online now   Reply With Quote
Old 16th Nov 2022, 3:43 am   #12
FrankB
If you turn a can of air duster upside down, it will act as freeze. I have used that trick quite often.
FrankB is offline   Reply With Quote
Old 16th Nov 2022, 8:10 am   #13
Tim
Tim's Avatar
Another vote for inverted air duster. The dog poop freeze spray works well too but the cans are on the small side. Useful for getting you out of trouble.
Tim is offline   Reply With Quote
Old 11th Aug 2023, 6:21 pm   #14
chriswood1900
Default Hasn't Freezer spray got expensive.
Whilst fixing a tuner I used up my last drop of freezer spray and went online to CPC, Amazon, eBay etc and was seeing prices north of £20 I can't remember ever paying that much before and the last tin probably lasted 10 +years I presume it has had to be reformulated to meet some new rules, does anyone know a more economic option?
Chris Wood
BVWS Member
chriswood1900 is offline   Reply With Quote
Old 11th Aug 2023, 6:36 pm   #15
Bazz4CQJ
Bazz4CQJ's Avatar
Default Re: Hasn't Freezer spray got expensive.
Well, your friendly pub landlord holds small cylinders of CO2... but not sure how you go from there.
B
Bazz4CQJ is offline   Reply With Quote
Old 11th Aug 2023, 7:31 pm   #16
G6Tanuki
G6Tanuki's Avatar
You can get big cans of the stuff at a relatively-bargain price from anywhere that does plumbing supplies to the trade, where it is sold as 'pipe freezer'.
TURN IT UP! [I can't hear the Guitar] - TMBG.
Old 11th Aug 2023, 8:34 pm   #17
paulsherwin
paulsherwin's Avatar
Poundland used to sell small aerosols - not sure if they still do.
paulsherwin is online now   Reply With Quote
Old 11th Aug 2023, 10:00 pm   #18
Jez1234
I've used the stuff from plumbers merchants for 20+ years here with no problems.
Jez1234 is offline   Reply With Quote
Old 12th Aug 2023, 10:20 am   #19
sortedradio
sortedradio's Avatar
I bought some Kalte freezer spray from "60 oldjohn" of this forum last year. It may be worth contacting him to see if he has any left for sale. It's been very good when I have used it, leaving no residue.
Martin
BVWS member
GQRP Club
sortedradio is offline   Reply With Quote
Old 12th Aug 2023, 10:36 am   #20
high_vacuum_house
high_vacuum_house's Avatar
I have used an “air duster” from Poundland quite recently. It is quite cheap at £1-2 a can and the evaporation of the propellant makes a surface go cold. Possibly not to the extent of freezer spray but probably good enough to cool components down. I believe it is also non flammable.
Christopher Capener
A proper radio is one that needs to be moved with a wheelbarrow !!
high_vacuum_house is offline   Reply With Quote
Reply
