#61 |
It was mentioned on another thread a few years ago that small electrical appliances in the USA were often provided with crowbar circuitry to prevent them from being damaged by overvoltage due to lost neutrals. It is common for US domestic premises to be supplied with a 240V single phase supply and a transformer with a centre-tapped 240V secondary that provides two 120V circuits for their mains sockets and lighting. If the centre tap goes open circuit, the two 120V circuits end up in series, and with a high current appliance on one circuit and a low current one on the other, most of the 240V will appear across the low current appliance. The crowbar detects the overvoltage condition and creates a short circuit to blow the appliance's internal mains fuse.
#62 | ||
![]() Quote:
#63 |
I recently had several power cuts, presumably due to flooding. Mains voltage was only about 200/210 volts at one point. I suspect that power normally supplied by the nearest substation, was in fact "back fed" from a slightly more distant substation. This reduces the voltage both due to losses in the longer cable route and by increasing the load on the assisting substation.
