13th Mar 2012, 1:27 pm | #1 |
Dial removal
Hi
I have a Bush portable radio TR82 C which I need to remove the tuning knob from so that I can get to the chassis. Now the manual says it just pulls of but mine is stuck fast, the surrounding dial is just plastic so I am concerned that to much pulling and it will crack. Has anyone tried to remove one of these and can offer any ideas of the best way to do it. Cheers in advance Mike |
13th Mar 2012, 1:39 pm | #2 |
Re: Dial removal
The usual method is to slip a boot lace behind it, getting the lace as near to the centre as possible, then pulling whilst gently rocking it at the same time.
Take care to ensure the lace doesn't snag the cursor. |
13th Mar 2012, 1:47 pm | #3 |
Re: Dial removal
Darren's advice is spot-on. Not too much rocking though!
Try to get the cord/lace in a figure-of-eight shape, so that it's pulling evenly on both sides of the spindle, not just one one side. Nick. |
13th Mar 2012, 3:55 pm | #4 |
Re: Dial removal
May I add, best not go in to a cold workshop and attack it, perspex is slightly less brittle at room tempreture (temperature). John.
13th Mar 2012, 5:59 pm | #5 |
Re: Dial removal
I tried this method with some thin nylon cord plus I also managed to get the thin tube you get on a WD40 can under the dial and get a few drops on the shaft then laid it, dial down to let it soak into the back of the knob, it worked a treat.
Many thanks Mike |
13th Mar 2012, 6:18 pm | #6 |
Re: Dial removal
Be careful with things like thin nylon cord as they localise the pulling tension too much and can crack the dial. Things like boot laces are much better, being softer and thicker.
14th Mar 2012, 2:04 pm | #7 |
Re: Dial removal
Mike, don't take offense at my question but is it an original British TR82C and not the later Chinese reproduction model?
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it! |
14th Mar 2012, 2:06 pm | #8 |
Re: Dial removal
14th Mar 2012, 2:09 pm | #9 |
Re: Dial removal
Correct
14th Mar 2012, 2:10 pm | #10 |
Re: Dial removal
Also 'affectionately' referred to as the "Wonky U" version.
14th Mar 2012, 4:26 pm | #11 | ||
Re: Dial removal
By the way, there was a thread from 2005 which discussed various methods of dial removal on these Bush models here, including the plunger method recommended by Bush themselves. Regards Last edited by Robert Darwent; 14th Mar 2012 at 4:36 pm. |
14th Mar 2012, 4:27 pm | #12 |
Re: Dial removal
On my VTR103 I simply kept pulling the dial off one side then 'tother by hand, it did take a while, about 15 miniutes. When I replaced it I slackened the spring a bit and put some silicone grease (don't use ordinary hydrocarbon stuff, it can affect plastic and sets like glue in a few years) on the the shaft. It has been suggested pullling the chassis out therefore supporting the knob all the way round.
14th Mar 2012, 8:57 pm | #13 |
Re: Dial removal
Hello all
No this is an original model from the 1960s,given to me in cosmetically pretty good condition although it was not working. On giving it the once over I found the problems where a dirty wave change switch and a broken earphone socket, very simple really and now it sounds great. Mike |
