15th Jan 2012, 1:53 pm | #1 |
Grundig and cat urine.
Dear Gang,
I have a lovely 1956 Grundig 3028 3D sound, restored professionally 4 years ago. In the last few weeks, my partner's cat has decided to use it to urinate on, straight into the front screen. Questions: Is it possible to restore? I'm afraid that turning it on will heat up the urine and make it much, much worse so it has not been used since the incident. I don't suppose anyone has had this problem? If you did, how did you get the radio back? Many thanks! MCA |
15th Jan 2012, 3:18 pm | #2 |
Re: Grundig and cat urine
These radios have a selenium rectifier that smells, exactly, like cats urine when it's failing. Are your sure it has actually been hit with cats urine or does it just smell like it has? David |
15th Jan 2012, 3:32 pm | #3 |
Presumably you've already cleaned the exterior of the radio? Urine transforms into ammonia and this will cause cabinet damage, although if it's only happened once you've probably got away with it.
As it happened "in the last few weeks" the urine has most likely dried up by now. Any smell will eventually go of its own accord but I'd be inclined to remove the chassis and clean where any urine may have found its way inside the cabinet. Diluted disinfectant or a neutralising spray from a pet shop will do it. Having done that, ensure the radio is properly dry before applying power again. DO NOT attempt to clean, or allow any liquid to get onto, the printed side of the tuning scale or allow any liquid onto the loudspeaker cones. |
15th Jan 2012, 3:32 pm | #4 |
Re: Grundig and cat urine.
If its a case of ridding yourself of the smell from the puddy-cat's work, try a bowl of vinegar left the case, and then mop out with a vinegar soaked sponge. Only, don't then use said vinegar on your 'Rock salmon' and chips!
Barry |
15th Jan 2012, 7:07 pm | #5 |
Thank you for your replies!
Yes, it is most definitely cat urine and several times as best I can tell. Thus far she has urinated on my 1840s cello, a lovely walnut Art Nouveau dresser and some antique stained glass....don't get me started on what I would like to do to her! Anyway, the radio was being stored, unplugged, next to the afore-mentioed dresser for several weeks and I have just discovered the damage a few days ago. There is green corrosion spots all over the grille and the badge and it is fragrant if you get your nose to it. I have not touched it other than to move it to a safe place and decided to turn to the more knowledgable people here before offering it on Freecycle. Can one use one of the proprietary cat-urine cleaners? What should I wash the grille with? &c So, advice please on how to get started or should I send it out to someone to redo it over again. Thanks again for any advice! MCA |
18th Jan 2012, 12:21 pm | #6 |
"Simple solution" available from pet stores has neutralising enzimes and will help greatly in reducing the smell. We have two dogs and my wife is a childminder so I can attest to this stuff's effectiveness on anything organic!
18th Jan 2012, 12:30 pm | #7 |
Hi.
It is really not the way to go just neutralising the smell, its important that the chemicals in urine are neutralised, for that its water! You will need to remove the chassis and all electrical parts and wash any effected parts. thoroughly dry the cabinet and reassemble. Cats and vintage don't mix I am afraid!
11th Feb 2012, 4:41 am | #8 |
OK but what are you going to do to the cat?
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it! |
11th Feb 2012, 11:47 am | #9 |
There's far too many feline fanciers on here for any serious discussion about that to go unmoderated!
Better stick to how to mitigate the effects rather than the cause
11th Feb 2012, 9:56 pm | #10 |
Actually, it would probably be best to concentrate on the cause to prevent a recurrence as well as dealing with the current problem, particularly as it is not only the radio (which, presumably, can be kept out of harm's way) which is a potential target!
I'm aware of un-neutered males spraying (and what a stink they make!) but not females so I consulted the resident expert (my wife) and she says that it is often related to stress or, sometimes, territorial invasion by other cats. She mentioned something called Feliway http://www.feliway.com/gb. Never having had cause to use it, I'm certainly not promoting the product here but I've included the link because it features a "cat stress risk barometer" which might be helpful in pinpointing problem areas. I would also endorse the suggestion the site makes to consult your vet for more information. I note that un-neutered females are also more likely to spray. The mods would probably have a fit if I was to start pontificating over this, so suffice it to say that all cat charities (including the one my wife is involved with) and vets (that I've heard express an opinion) all sing from the same hymn sheet on this one! |
11th Feb 2012, 10:48 pm | #11 |
We had a Siamese that used to wee in the toaster, you didn't find out until you went to use it and it then took a week to get rid of the smell. We eventually cured it by getting one that fixed to the wall (toaster not cat).
Peter |
11th Feb 2012, 11:02 pm | #12 | |
Surely the mods wouldn't remove a post that gave sensible advice. We don't have cats, both my wife and daughter have serious cat phobias and to cap it all my daughter can go into an asthma attack in a house that has a cat even though is not in the room she is in! If I did have a cat I would make sure that it was not allowed near my collection, in other words the collection and cat could not cross paths, so if you want your prized items in the lounge or living area don't have a cat, likewise if you want the cat in the living area put your collection in a secure room!
12th Feb 2012, 12:57 am | #13 |
'twas the question "What are you going to do to the cat?" that prompted my response. (My italics.)
I wasn't being at all sensible
18th Feb 2012, 7:35 pm | #14 |
Must admit reading this is making me feel slightly green. I had endless problems with cat urine in television receivers and VCR's. In most cases the equipment is a write off. I have seen large areas of print on printed circuit panels literally vanish! Very corrosive stuff and once they do it, very difficult to stop them. Suggest you put everything in the house or flat into plastic bags and only open when the coast is clear. Cheers, John.
20th Feb 2012, 2:07 pm | #15 |
20th Feb 2012, 2:10 pm | #16 |
20th Feb 2012, 7:07 pm | #17 |
MCA has come here for our help, so I don't think we should be taking the xxxx!
Greg
Greg BVWS committee chairman |
20th Feb 2012, 8:21 pm | #18 |
Hi, Marian, MCA1928, listed this radio on Birmingham Freecycle at the end of Jan. I responded to the listing, not realizing that it was the "Cat soiled" Grundig I'd read about on here earlier in the month. Marian responded to my offer of a new home by saying that she'd decided to keep the radio, but offered me the opportunity to restore it for her. I declined, as my speed of repair would not be suitable for her, but suggested she placed another post on here asking for a local repairer willing to take it on (I'd realized by now that she was MCA1928). It appears she has not returned to the forum since her initial posts on 15th Jan.
If anyone wants to offer her a repair service drop her a PM. Les |
20th Feb 2012, 10:39 pm | #19 |
As this thread has now drifted way off topic it's time to put the cat out.
Brian |
