Old 28th Mar 2008, 5:22 pm   #1
Boom
Default Help please oddball DAC90 fault
I've picked up an extremely clean DAC90 which I would like to get going.
First I removed the eternal speaker socket that someone had fitted
(yep really) and while doing so noted the single pole on/off switch
is wired through the neutral to chassis! This means the chassis becomes
live when the set is switched off even if wired the 'correct' way around!
The problem:
The output is very quiet almost silent but the AF stages are fine with lots
of 'finger hum'. Very occasionally the set will work normally but then drop
volume again.
Voltages are pretty much what they should be except for the AGC which
seems to be all over the place but I suspect this could be a symptom rather
than the problem. The CCH35 and EF39 have been replaced with no joy.
The problem seems to be in the IF stages and I have a sinking feeling that
the IF transformer feeding the EF39 itself might be faulty. Continuity is
present on primary and secondary windings so if faulty I would suspect
shorting turns.
Can anyone confirm or deny that the IF transformers go faulty in this way
or if you all say 'Not in a Million years, it doesn't happen on a DAC90' I'll
look again but I really am flummoxed.
One small oddball I noticed is that I get finger hum from the EF39 top cap.
Is this correct? It's an IF stage after all.
The problem is made hard to investigate as I have mislaid my isolation
transformer so can't get a 'scope connected.
Thanks for any help or suggestions - Dave
Boom is offline
Old 28th Mar 2008, 5:37 pm   #2
Ian - G4JQT
Ian - G4JQT's Avatar
Default Re: Help please oddball DAC90 fault
The mains-switch wiring is normal. This thread explains: https://www.vintage-radio.net/forum/...6336&highlight
If the IF transformers have not lost continuity, check that one of the ferrite cores has not come lose from their brass thread and knocked it right off resonance. But if so, carefull "supergluing" can fix it, but don't take the IF can appart to do this until you have checked everything else. To be honest, you should get something even with a poorly alighed IF stage, so a broken core sounds like a last resort!
Ian
Ian - G4JQT is offline
Old 28th Mar 2008, 5:40 pm   #3
Steve_P
Steve_P's Avatar
Change everything on the AGC Rail if you're not sure!
Have you subbed V3?
Have you done a capacitor change, including the ones across the IF Cans?
Have you got a Signal Generator. If you have, it's 465 kHz and go via suitable caps to the anode of V2. Then the anode of V1 and tune the IF up if you can. It could have been tweaked onto the wrong frequency.
Cheers,
Steve P.
The manual is available up top if needed.
Steve_P is offline
Old 28th Mar 2008, 5:48 pm   #4
Boom
Have you subbed V3?
Thanks Steve. Yes I have changed V3 and can't change the IF caps' as they are inside the can which is going to be a pig to get at so I want to leave that to a last resort. I'm really asking if anyone else has had these pack up or not.
The high values resistors on the AGC line all measure ok as do the caps'.
No way of genneying a 455 at present. When the fault clears the IF's do indeed peak. This is what is saying to me it might not be them. I'd have thought the caps' would be either good or/s but then again shorted turns might just come and go. It really is doing my head in.
Boom is offline
Old 28th Mar 2008, 5:58 pm   #5
Boom
Many thanks all. Think it is sussed. The set came to life again and the IF peak is indeed changing during the fault so it looks almost certain that either a cap across the transformer is going o/c or is dry jointed. I'll have to take the can out and sit down with it. Looks a horrible long job.
Many thanks again for all your help.
Boom is offline
Old 28th Mar 2008, 8:01 pm   #6
af024
Hello Dave,
I had one with a dodgy mica cap inside the IF transformer and another where an IF transformer winding was intermittent.
I hope you find it. These intermittent faults can be a pain.
Best of luck,
Andy
Now where on earth did I remove that from?
af024 is offline
Old 28th Mar 2008, 8:03 pm   #7
Boom
Ian
Many thanks Ian. Dead on. The slugs had fallen off the threads and were floating about as I turned the set upside down to work on it hence the sometimes working bit! I Araldited what was left of them back in place which has got it working but it has taken me 2 hours. I'll stick to DAC90A's in future. Far less hassle.
Thanks again - Dave
Boom is offline
Old 28th Mar 2008, 8:31 pm   #8
telstar
Hi. The problem on both my DAC90's was with the I.F.T slugs breaking away from their brass formers. It really was a pain to superglue the fragments of the slugs together again (luckily the breaks were fairly straightforward, and not any worse).
Another strange fault that I had was the cathode resistor of the CL33 output valve changing value when the set was switched on (its value was ok when "cold"). I have never experienced this problem in any other radio - I replaced the resistor and it seemed to work normally again.
Regards
Mike
telstar is offline
