#1 |
Here is a part recently removed from a CFL fitting of about 20 yrs ago.
It is the type where the tube had a base consisting of 4 four pins arranged around a square spigot. The tubes themselves were two side by side and U shaped, maybe 6" long. There were lots of these CFLs around but I forget which brand was on them, GE possibly among others? Inside the lampholder was a PCB, it has bridge rectifier feeding some 22uF 200V capacitors in series and some Sw_mode trickery following. Good to harvest for parts. I am interested in the input filter inductor. It looks like this. Two pretty identical windings wound on an ungapped(probably) ferrite core . Any ideas what the ballpark inductance of this might be please? My facilites for measurement of inductance are lacking. |
#2 |
I guess it's a common-mode RFI-suppression choke, with the 2 windings intended to sit in the L and L supply-lines.
#3 |
Not knowing the design details, it is going to be hard to say without being able to measure it.
To give you an idea of the possible range, I looked up Coilcrafts common mode filters and the inductance values vary between 130uH and 45 mH. That is only indicative, other manufacturers could be very different. |
#4 |
Thanks both, yes that's what it is. I'm going to try and guess the inductance by adding a capacitor and looking for resonance.
#5 |
3.9mH
- Julian It's good here ![]() |
#6 |
Another example, 3.5mH
These are from smaller CFLs than yours, I think
#7 |
Larger CFLs may have much lower inductance chokes: this one is from a CFL with three U-shaped tubes, rated at 20W. The inductance measures only 0.15mH, though that makes me suspicious that it has shorted turns
#8 |
I must correct my last post: the inductor is tapped. The former broke up as I removed it so I don't know how the two turns were connected, but it may have had a lot more inductance with the turns in series
Oh, btw, I do love this android app Magnifier Plus, it's better than a loupe for seeing small details, plus you can save the images
#9 |
More on this inductor: the core has a much greater air (glue) gap than the others, about 0.2mm compared with a layer of thin superglue on the others. From this I conclude that it was for a smps operating at high frequency, and nothing to do with RFI suppression
#10 | |
![]() Quote:
That's really handy, Jules! Looking forward to using that!
Best wishes, Al "Plans are useless but planning is indespensible..." (Eisenhower). |
#11 |
Agreed, that magnifier is really useful.
No more done with the inductor but thanks for all the inputs. |
