9th Nov 2014, 12:24 am | #21 |
Re: Soldering Aluminium
I used to have a little Valtock jeweller's meths blowlamp that was quite useful and served for soldering away from mains for me. Not sure where it is now.
9th Nov 2014, 11:56 pm | #22 | |
This repair material from Magna is usefull to replace brushes on some of those modern motors with aluminium field windings and all that is available of brushes are those with copper braids. They have to be attached somehow or the motor scrapped. In production they are "resistance" welded or almalgamated aluminium to copper. Regardless, shame I did not keep the sample that I hard soldered together. |
10th Nov 2014, 9:27 pm | #23 | |
The flux used in joining aluminium to copper and brass was the key component to the sucess of the "filler material" or solder if you will. The flux was a powder that had to be mixed with distilled water prior to use.
Tony |
11th Nov 2014, 5:07 pm | #24 | |
I've also used the 'rubbing' method on stainless steel (or it may have been 'staybright' or similar) I wanted to join a length of wire to a s/s whip antenna, but couldn't be bothered finding some acidic flux or whatever is required. So I used an ordinary 25 watt iron, ordinary flux and plenty of rubbing. After quite a while a tiny pinprick of solder bonded, and after that I managed to make it cover a larger area and successfully soldered the wire in place.
Andy G1HBE. |
12th Nov 2014, 10:39 am | #25 |
This has reminded me of an advert I saw in an old technical magazine, probably from the 1950s or 60s. It was a soldering iron I think by Solon specifically for soldering aluminium. It looked like a normal soldering iron with a piezo electric unit that produced a sonic vibration at the tip. This was claimed to clear away the oxide on the metal. I have seen no references to it since so suspect it was not very successful.
