Old 15th Jul 2019, 9:56 pm   #1
Jolly 7
Default Dismantled VCR component mounting etc.
Recently I have been dismantling some VCRs and came across a common theme of soldering. The power supply diodes haven't been soldered flush to the PCB and some of the larger resistors also have a gap between them and the board. Has this got anything to do with heat dissipation ?
Jolly 7 is offline
Old 15th Jul 2019, 10:32 pm   #2
ben
ben's Avatar
Default Re: Dismantled VCR component mounting etc.
Almost certainly, stops the board getting damaged and carbonizing in use.
Personally I would avoid reusing most components from the PSU as they lead a hot and hard life. The SMPS transistor is probably worth saving, plus any obscur schottky diodes etc. Forget the caps though.
Regards,
Ben.
ben is offline
Old 15th Jul 2019, 10:58 pm   #3
Jolly 7
Thanks. I dismantled the VCRs for the BLDC motors, so anything else worth salvaging would be nice too. Apart from the semiconductors, there are some blue blob-like inductors and infrared receiving diodes that I might want to desolder.
Jolly 7 is offline
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
