26th Jan 2016, 6:39 pm | #1 |
Location: Ellesmere, Shropshire, UK & Co. Cork, Ireland.
Whiskery AF117 - on the outside!
I looked inside my Bush TR82B just now to check nothing unpleasant was going on with the rather old PP9 battery. Something caught my eye...sparkling. There on the case of a slightly corroded looking AF117 are...whiskers.
The other AF117s seem to have a smear of a greasy substance or no 'fuzziness'. Attached is a picture - a prominent whisker is on the right hand side. The picture does not do the metallic twinkling justice. I'd love to see inside if the same effect is happening... |
26th Jan 2016, 7:43 pm | #2 |
Re: Whiskery AF117 - on the outside!
Never seen that on the outside before, I bet the inside is fine
I have seen this happen on pot housings though, classic tin migration. Oh yes, it does cause problems with pots. I opened up an intermittent pot that would not respond to Servisol, I was amazed at the amount of tin whiskers growing from the metal casing. I cleaned it out thoroughly and painted the inside of the casing with some enamel paint. No problems with it since. Mark |
26th Jan 2016, 8:39 pm | #3 |
I've not seen that for a while. It does remind me of a time when I picked up an old guitar I have and found that the knobs on the machine heads just fell apart. Maybe a similar problem although these were obviously very cheap.
26th Jan 2016, 9:15 pm | #4 |
I found a huge amount of whiskers on the tuning dial frame in my low distortion sine wave generator.
26th Jan 2016, 9:24 pm | #5 |
I've found them in some WW2 era comms receivers on soldered joints and cadmium? plated chassis.
Lawrence. |
27th Jan 2016, 1:10 am | #6 |
I have no idea what Marconi plated the chassis with but all the same it is clearly covered with whiskers on the tuner metalwork.
27th Jan 2016, 11:59 am | #7 |
Zinc is another metal prone to this phenomena.
Pete |
27th Jan 2016, 1:39 pm | #8 |
Are the whiskers on the Refugee's tuning dial, actual metal whiskers or just crystalline corrosion salts though?
Zinc does give rise to light fluffy corrosion - probably zinc hydroxide - but this is a different phenomenon to the tin whisker problem, where it is actual metal migration which is the problem. |
