17th Nov 2021, 4:22 pm | #1 |
Mystery 2 pin connector to identify
These were amongst a job lot of bits and pieces that I recently acquired.
Does anyone know what they are called and their main application(s)? |
17th Nov 2021, 4:31 pm | #2 |
Re: Mystery 2 pin connector to identify
Possibly home made, for connection to dry batteries that had a socket outlet, AD 28, HP 1, and various HT batteries.
17th Nov 2021, 7:24 pm | #3 |
The Paxolin circle is reminiscent of a fluorescent light starter contact plate- perhaps, as broadgage says, it was adapted for battery contact use.
17th Nov 2021, 7:36 pm | #4 |
Another possibility is the type of plug used for headphones in the crystal set era.
I assume that the two holes in the paxolin are a crude form of cable grip. Alternatively a loop of cord could be attached to help to unplug it. |
17th Nov 2021, 7:48 pm | #5 |
How big is it?
Its not dissimilar to the power connector so beloved by Bush on DAC90s and similar sets if its that sort of size Cheers Mike T
17th Nov 2021, 7:58 pm | #6 |
The two holes at 90-degrees to the pins suggest they could have been for the connecting flex to feed through as a kind of strain-relief for the flex-to-pin connections.
I'd think it was a battery-connector, or maybe used to connect an extension-speaker to a radio.
17th Nov 2021, 8:22 pm | #7 |
I should have added a ruler in my previous photos to give some idea of size. Here’s one now.
My digital micrometer says the pins are 1.97 mm diameter. I doubt it was for HT or LT battery connections, as the two pins are the same diameter, so not polarised. Still intrigued as to its use(s). |
24th Nov 2021, 2:21 pm | #8 |
Possibly a battery connector despite not being polarised.
Incorrect polarity of the heater supply seldom matters, and HT could be determined by trial end error without harm, as when connecting a valve set to DC mains. |
24th Nov 2021, 10:51 pm | #9 |
Antenna/earth connector or speaker connector as already mentioned?
