Old 9th Jul 2018, 2:17 pm   #1
percival007
percival007's Avatar
Default Maplin Precision Gold XG95D
Hi All,
a bit of a long shot here I think.
I have a Maplin 'Precision Gold' (their own Brand (?)) XG95D Dual Power Supply.
Not necessarily Vintage I suppose but I have had it donkeys years.
The thing works absolutely fine as a PSU but the 'Separation' LED no longer lights. There are two LED's, one ('Separation') for when the two Supplies are working independently and a 'Tracking' LED for when the Right Hand Controls adjust both Supplies for a tracked +/- Supply. Both functions are working as I say, just the LED for Separate function does not light. It's not the LED, there appears to be incorrect voltage across it.
Before I start fully dismantling it and drawing out the circuit I wonder if there ever was a Schematic for this available from Maplins and if so, does anyone have a copy?
It's no real problem but I have been re-arranging the workshop in readiness for a new 'Scope and thought I'd have a look whilst it was accessible.
Thanks All,
James.
percival007 is offline
Old 9th Jul 2018, 8:22 pm   #2
buggies
buggies's Avatar
Default Re: Maplin Precision Gold XG95D
I don't know the unit - but would start by looking at the switch contacts - possibly one half of the switch doing the PSU control and another just doing the LEDs?
George
buggies is online now
Old 10th Jul 2018, 2:18 pm   #3
dave cox
dave cox's Avatar
A photo might help in case its a re-badged product.
dc
dave cox is offline
Old 10th Jul 2018, 7:44 pm   #4
sortedradio
sortedradio's Avatar
"It's not the LED, there appears to be incorrect voltage across it."
If the voltage across the LED is incorrect could it be that the LED is open circuit? Is it difficult to substitute another LED in its place?
Martin
BVWS member
GQRP Club
sortedradio is offline
Old 10th Jul 2018, 8:26 pm   #5
David G4EBT
David G4EBT's Avatar
Or (with the PSU switched off), to apply a small Voltage across the LED via a limiting resistor, say 3V via 470R, to see if the LED really is duff.
Good luck with it James.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 16th Jul 2018, 9:53 am   #6
percival007
Sorry for the delay in replying, have not had a chance to look at the PSU again untill yesterday.
Thanks sortedradio, yes indeed it turned to be the LED and yes it was a tricky job to change it, the whole PSU front Panel having to come off. One reason I looked elsewhere first. The other reason was getting fooled by the incorrect voltage measurable across but discounting the fact that it could be the LED itself ! Silly mistake.
Thanks all,
James.
P.S. I will try and post a pic for your info soon.
