30th Sep 2021, 9:38 pm | #1 |
Newbie question regarding picture quality...
Is there a common component we can pinpoint that is responsible for why a picture is clear versus a picture that has some static in it? I recently started getting a few old tvs, just due to nostalgia, not because of any technical knowledge. This was my set-up:
- Fire stick goes into... - HDMI to RCA adapter... - Then it goes to the RCA input off a RF Modulator.. - RF Modulator then goes out via coaxial... - This coaxial goes into the 75 to 300 ohm VHF adapter... - The adapter is then connected to the VHF terminals. First tv I tested was a Zenith black and white from the late 70's. The picture came out perfect! Not a freckle! I call static freckles. LOL! The second TV is also a late 70's by Sharp. Both are small 9 inch tvs. But this Sharp TV required a lot of fiddling with all the knobs. The picture I get is okay, but I can see freckles/static. Actually, the picture the Sharp produced was closer to my expectations coming into this new hobby. Something that's decent with some static. But now the Zenith made me realized even old tvs can have crisp, clear pictures. It just blows away the Sharp picture. Do you guys have any recommendations what I can do? I exhausted all the available knobs on the Sharp, including the black ones in the back for vertical, horizontal, etc. Even on the VHF channel knob, there is an outer knob for fine tuning, and I messed with that as well. Could it be as simple as some component inside that's dusty that needs to be cleaned? How about an agile modulator that allows me to pick something else other than channels 3 or 4. Could that help picture quality? Please advise, thank you in advance. Last edited by obsolete man; 30th Sep 2021 at 9:47 pm. |
30th Sep 2021, 10:44 pm | #2 | |
Re: Newbie question regarding picture quality...
The "snowy" picture might not be insufficient signal from your modulator, it might well be because there is a strong digital signal on each VHF channel you are trying, and they may be strong enough to interfere with your analog signal even without an antenna. It may be that some of your sets fare better than others because of better front-end screening etc. We use a different digital system in Europe, (and we only use UHF in the UK), but I suspect like our DVB-T, your ATSC system will look like snow when viewed on an analog set.
-- Graham. G3ZVT |
30th Sep 2021, 11:17 pm | #3 | ||
1st Oct 2021, 1:00 am | #4 |
Another problem might be that the modulator is probably the finest Chineseium and have a spec that some old sets might not tolerate so well.
So you could try an analog antenna distribution amp preferably an old pre-digital one ( used for feeding different rooms off the one antenna) some of these have a gain control you can twiddle around with to try and balance the signal. The modulator would feed into this then the outputs would feed the TVs. |
1st Oct 2021, 1:51 am | #5 | |
1st Oct 2021, 2:10 am | #6 |
Blonder Tongue AM series agile modulators are often offered on Ebay for reasonable money - these are professional quality units and most have a high level signal output which can be used to feed a passive splitter without further amplification
Rgds John |
1st Oct 2021, 3:09 am | #7 |
I'm looking at them on eBay, but I'm not sure how to use them. My current RF modulator has RCA composite inputs. How would I connect my source to those Blonder Tongue models?
1st Oct 2021, 9:26 am | #8 | ||
I suspect a better modulator would improve thing further and possibly the newer the set, the more tolerant it would be… A guy i was chatting to in the US definitely felt consumer modulators are much poorer than commercial ones. I suppose you get what you pay for.. Patrick Last edited by patrickgnl; 1st Oct 2021 at 9:29 am. Reason: Addition added |
1st Oct 2021, 3:22 pm | #9 |
Watching "Vintage" TV on early TV sets in the USA has quite a following and no less so than in LA.
For many, the technology itself is not so important as being able to demonstrate to others that it can be done and to make new friends through the hobby. Because it has been some time since analogue TV has been switched off and replaced by digital, the reason why channels 3 or 4 can be chosen and or the different TV systems used around the world have "got lost in the either." Your basic set up, as described, makes perfect sense and whilst the description "static" and "freckles" sound OK, it is worth remembering that it can be misleading to use such terms when trying to describe a fault. For example, when a analogue TV set is switched on without an aerial, the freckles on the screen and noise from the speaker is in fact the noise generated by the circuits inside the TV. When connected to a signal stronger than the internal noise, the picture is free of the interference and, because the TV uses FM sound, the sound does not have a background of hiss. Now, you say that the Zenith gave a good picture and sound which was not so with the other sets which it is said that the modulator you are using isn't good enough. This may be so or the channel 4 might be better than 3, but to prove the point, I would see the Zenith as your reference set. Connect as you have and then tease out the 75 to 300 ohm adaptor so making the signal poorer. You should notice that picture starts to have black specks on the screen. This is noise from a weak signal. Note, the US analogue signal is negative modulation, hence black noise. Now, with this in mind connect the other TV's and see what the picture is like. Black spots noise, white spots, something else. A picture says a thousand words and so feel free to illustrate the pictures accordingly using the experience of the Zenith to get a feel of how the controls affect the picture. Good Luck, my names Chris. What's yours. |
1st Oct 2021, 6:09 pm | #10 | |
Regards, John |
1st Oct 2021, 6:33 pm | #11 | ||
https://www.ebay.com/itm/14412213430...IAAOSwV6dg-L~e If you look in the center you will see the gain control, and it looks like it has an FM blocker presumably to stop interference from radio transmissions. Looks like you will need some 'F plugs' (male) to connect it but they should be easy to obtain. . Last edited by cheerfulcharlie; 1st Oct 2021 at 6:53 pm. |
1st Oct 2021, 7:20 pm | #12 | |
user manuals are available online J |
1st Oct 2021, 7:38 pm | #13 |
I am sure that US ATSC digital TV uses UHF transmitters just as in the UK but unlike here, channel numbers shown on the TV don't. For example, as UHF transmission was phased in and VHF assigned to other services, the TV would show KVHD Ch3, the local station, when in fact UHF ch 60 was tuned. This was so the less technical could find their way around the new analogue UHF stations. This may be why a couple of UK posts refer to interference from existing high power Ch 3 transmitters.
As the Modulator you are using works well with the Zenith, personally, I would leave all alone and show screen shots of the other TV's. Buying new bits of kit in the hope of making another set better may not help. Chris |
1st Oct 2021, 9:14 pm | #14 | ||
1st Oct 2021, 9:25 pm | #15 | |
Brandon |
1st Oct 2021, 9:30 pm | #16 | |
While the above described channel number aliasing is in use, the use of real VHF frequencies is also employed and has in fact expanded in the years following analogue switch off - some channels which initially used UHF frequencies have switched to VHF for a variety of reasons including the vastly superior propagation characteristics of VHF - this has led to stiff competition for VHF TV transmission licences J |
2nd Oct 2021, 3:00 am | #17 | ||
2nd Oct 2021, 10:17 am | #18 | |||
2nd Oct 2021, 10:43 am | #19 |
Okay guys, here is a picture of the Zenith picture quality...
Here is the Sharp... Here is a link to a sample of the Zenith video: https://youtu.be/rxd6hPlz4Kc Here is a link to a sample of the Sharp: https://youtu.be/kq9vkrIIh1A Another Sharp sample video: https://youtu.be/NRbsyMHtNm8 Regarding the Sharp videos, you'll notice not just the snow, but some sort of glitch that looks like a lightning effect. Is that lightning effect a telltale sign of anything? Thanks! |
2nd Oct 2021, 11:06 am | #20 |
On your Sharp, if there is some EHT discharge caused by defective EHT rectifier or any
associated sparking that might lead to interference on the picture. However the noisy picture gives the impression the tuner input stage is defective, possibly a faulty transistor. The VHF tuner will also be used as an IF preamplifier on UHF, so if that too was noisy, that might confirm the diagnosis. Note sure if you can obtain a UHF modulator locally, they were standard in the UK. |
