Old 5th Jul 2010, 12:48 pm   #1
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
Default 5 Band resistor Colour Code
Can someone refresh my memory as to this. I know that the 1st colour is 1st figure, 2nd C. is 2nd Fig., 3rd is multiplier, all using the conventional colour codes with which we are all familiar. My question concerns the last two bands, one of which is tolerance, what is the other, and which is which?
'LIVEWIRE?' is offline
Old 5th Jul 2010, 1:15 pm   #2
Tim
Tim's Avatar
Default Re: 5 Band resistor Colour Code
ISTR it is Temerature co-efficient. But as to which way round they are, haven't a clue.
Anything with more than four bands I check with a DVM.................
Then there are those ones with a total of six (FOUR bands for the value), which I have never got to grips with, never knowing which end to start!
Tim is offline
Old 5th Jul 2010, 1:20 pm   #3
AlanBeckett
See attached.
Google resistor colour code and you'll get lots of pretty ones
Alan
AlanBeckett is offline
Old 5th Jul 2010, 1:23 pm   #4
threeseven
threeseven's Avatar
It's for tight tolerance with a temp coefficient.
See this :-
http://en.wikipedia.org/wiki/Resistor_color_code
threeseven is offline
Old 5th Jul 2010, 2:06 pm   #5
kalee20
However a lot of modern resistors are marked: Band 1 first figure, Band 2 second figure, band 3 THIRD FIGURE!, band 4 number of zeros, band 5 tolerance (usually 1%, occasionally 2% for these 3-figure codes). And that makes 5 bands! So 1k 1% is marked, brown, black, black, black, brown, brown.
kalee20 is offline
Old 5th Jul 2010, 2:13 pm   #6
Tim
Tim's Avatar
Be Ok with 1.1 k I suppose.
Tim is offline
Old 5th Jul 2010, 5:05 pm   #7
But not so good when you get a batch of boards with 120R 1% fitted instead of 10K 1%. BTDT
Herald1360 is offline
Old 5th Jul 2010, 7:17 pm   #8
'LIVEWIRE?'
My question arose due to what I thought was an o/c 47K resistor in a Marantz amplifier-this resistor being marked Yellow, Mauve, Brown, Red(or Orange), & Silver.
On checking the circuit diagram it turned out that this resistor is 47 OHMS(as per the first 3 colours) The Silver band = +/- 10% tolerance, but I'm still not sure what the red(?Orange?) band indicates.
Old 5th Jul 2010, 7:20 pm   #9
ppppenguin
ppppenguin's Avatar
Yellow 4
Violet 7
Brown 1
Gold x0.1
Silver 10%
Hence 47.1R, 10%
Very odd having 10% tolerance on a resistor specified to 3 significant digits.
ppppenguin is offline
Old 5th Jul 2010, 8:03 pm   #10
John M0GLN
John M0GLN's Avatar
High stability resistors used to have a pink band as the last one.
John M0GLN is offline
Old 5th Jul 2010, 10:22 pm   #11
McMurdo
McMurdo's Avatar
Mm that resistor colour code compared to its value doesnt make sense whichever way you read it.
Modern equipment never uses 10% resistors, minimum is 5 and usually 2%
Kevin
McMurdo is offline
Old 6th Jul 2010, 7:41 pm   #12
theoldtrout
You may find this free programme useful. I've used it as a teaching aid.
http://myfreewares.weebly.com/resist...de-solver.html
theoldtrout is offline
Old 6th Jul 2010, 8:58 pm   #13
Tim
Tim's Avatar
Looks fab
Thanks for that one.
Tim is offline
