24th Oct 2017, 2:28 pm | #1 |
Labgear "Viewing Unit"
Old Labgear "Viewing Unit" about 12.5 deep x 6.5 wide x 5.5 high.
No timebase or Y amplifier just a U16 2 volt valve rectifier with EHT about 1kv. Y sensitivity is stated as 1.5 volt per mm. The sweep is simply the live mains connected to the HOR input terminal via a 0.1mF capacitor. This produces a sweep sufficient to overscan. Images show the front panel, side views and crt etc There are 5 x 0.1 mF 450v capacitors which are leaking. My question is should I just replace with modern types naked or stuff them in the original cases?
George |
24th Oct 2017, 2:34 pm | #2 |
Re: Labgear "Viewing Unit"
Forgot to mention, there is a typed instruction manual which helpfully warns about the mains appearing on the front panel terminal when 50 c/s sweep selected!
George |
24th Oct 2017, 4:26 pm | #3 |
Well I love it! And as I have not seen one before I would re stuff or at the very least keep the old caps having changed them.
24th Oct 2017, 4:32 pm | #4 |
I agree, try to keep it looking original. But I'm aware there are many on here who will disagree and say simply use modern parts. There's no definitive answer!
Andy |
24th Oct 2017, 4:57 pm | #5 |
That's rather nice: I recall something similar being used by a G3-plus-2-letter ham of my acquaintance back in the 1960s, to produce a #'trapezium' display of his AM modulation-envelope.
24th Oct 2017, 9:54 pm | #6 |
Interesting unit!
I did smile at the instructions though. "Now, what precautions are we going to take to prevent the user being zapped with 700 Volts on the front panel terminals? I know: we'll just tell them not to touch it, that'll work!!" Cheers Nick |
24th Oct 2017, 10:26 pm | #7 |
When fully-fledged scopes were very expensive, this would still provide a lot of information about what was going on, presumably at a much lower price. Just as a high impedence voltmeter it would be pretty handy. As they say, it could later be extended with a proper timebase (and Y amp, I suppose). I wonder if they sold a suitable TB, or just expected that anyone with a use for one could design and build their own?
25th Oct 2017, 8:55 am | #8 | |
Andy |
25th Oct 2017, 3:47 pm | #9 |
Thanks for all the replies - I will stuff the new caps inside the original cardboard sleeves. Not sure if there will be sufficient old tar to use to seal the ends but I suppose beeswax would do?
I think the unit was probably produced in the late 40s as Labgear apparently liquidated in 1951 (according to google) and their name taken was by Philex. I obtained it from Harry, GM2TW around 1980. He probably did use it for modulation setting as described in the instruction manual. I used a couple of signal transformers to step up the voltage from a teleprinter two tone filter. Each tone was applied to the respective X/Y input to obtain a cross display to aid tuning on HF. There is a bulgin 5A plug (male pins) behind a plate on the rear panel which is connected to the switched live. The flexible wiring is all white pvc and I suspect this may have replaced rubber covered wires at some point so the wiring may not be correct. The mains cable was rubber and completely rigid. Rough sketch of circuit attached - I will redraw in Orcad when I have made some components and checked values and connections. The scanned instruction manual (7 pages) as a pdf file is too large to attach but should be available here:- https://www.dropbox.com/s/6xm9w6ose7w47x7/instruct.pdf
George |
25th Oct 2017, 11:33 pm | #10 |
That mains lead looks awful.
I bet the plug is still all right though. |
26th Oct 2017, 6:24 pm | #11 |
Surely Labgear were still going in the 1960s, maybe even 70s? Thinking of loads of amateur radio gear from the 60s. LG300, Low pass filters, mains filters, tv test gear etc.and I have a 160M tx by them.
Looks a nice, simple piece of kit though. Rob
26th Oct 2017, 7:00 pm | #12 |
Pye bought them in 1951. Still going today. Still making TV aerials.
I looked into them, as a local firm, when I saw a Radio Fault Locator unit they did. Their former home Willow Place has gone I was interested to find out where exactly it was. Under what is the Grafton Centre now! Andrew
26th Oct 2017, 8:46 pm | #13 |
wasn't there a name associated with Labgear.... Sant Karbana or something like that?
26th Oct 2017, 8:54 pm | #14 |
Sant Kharbanda, was the technical director at some point apparently.
Lawrence. |
26th Oct 2017, 9:16 pm | #15 |
Yep: he held the callsign G2PU. A quick search shows he had at least one TV-related patent in his name: https://patentimages.storage.googlea.../US2550821.pdf
Seems he died in January 2000. |
