Old 4th Feb 2023, 2:15 am   #1
jamesinnewcastl
jamesinnewcastl's Avatar
Default Tektronix 7000 Knob Wanted
Hi All
Just moved the lab about and horror - The small light grey 'button' on one of my 'identify position' knobs on a Tek 7000 series plug-in is missing! It's the button you press to bring the trace to the screen centre - see pic.
Anyone have one?
James
jamesinnewcastl is offline
Old 5th Feb 2023, 8:35 am   #2
Craig Sawyers
Craig Sawyers's Avatar
Default Re: Tektronix 7000 Knob Wanted
Let me have a look at one of my spares plugins. I'll let you know if one turns up.
Craig
Doomed for a certain term to walk the night
Craig Sawyers is offline
Old 5th Feb 2023, 10:46 am   #3
Craig Sawyers
Sorry - my main parts plug-in is missing that control entirely. I might have something in the attic - I'll check.
Craig
Old 5th Feb 2023, 2:45 pm   #4
jamesinnewcastl
Hi Craig
Thanks for looking - if nothing turns up I suppose I can 3D print one! I suspect that 3D printing is going to feature more highly in projects now I have dipped my toe in!
James
Old 5th Feb 2023, 4:53 pm   #5
Diabolical Artificer
Diabolical Artificer's Avatar
After a mega search I found this, see attached. Whilst not grey it came off a 5000 series rack mount scope.
It measures 10mm top dia, flares out a tad at base, 12mm deep, shaft is 3mm ish, secured by grub screw.
FOC, send me your address if any good, Andy.
Edit, don't think that'll do, found another one that's about half the size, shaft 1mm approx.
ID:	272744   Click image for larger version
Old 6th Feb 2023, 1:50 pm   #6
jamesinnewcastl
Hi Andy
Thanks for doing a big search, sadly the bit I need is the center part of the pic I showed. It's the bit that you press to find the trace so it is little more than a small cylinder with a rounded end!
James
Old 6th Feb 2023, 2:20 pm   #7
Craig Sawyers
I have a huge box of Tek spares too - in which I know there is a zip lock bag of random knobs.
I need to rummage that out and see if I have a trace identify button.
Craig
Old 6th Feb 2023, 6:07 pm   #8
Hi James, no worries, happy to help. I know the one you mean, I have a square one... typical,1000's of parts but not the right one. Hopefully someone will have one.
Andy.
Old 6th Feb 2023, 6:38 pm   #9
Nymrod121
Nymrod121's Avatar
I've had a look through my Tek bits / spares mules but no luck ... sorry!
Guy
Nymrod121 is offline
Old 7th Feb 2023, 6:18 pm   #10
dave cox
dave cox's Avatar
Did you sort this James ?
I have a spare, it's ~ 7mm long X 6mm (dia, at base) with a 3mm hole (with 3x internal lugs)
dc
dave cox is offline
Old 8th Feb 2023, 2:15 pm   #11
jamesinnewcastl
Hi Dave
No, still no part but what you have is the thing I'm looking for!
I'll send you a PM, thanks!
James
Old 15th Feb 2023, 3:00 pm   #12
jamesinnewcastl
Hi Moderators
Please close this thread, I've received the item from Dave Cox, thanks again Dave.
James
