Old 17th Jun 2016, 7:43 am   #1
Ti Pwun
Ti Pwun's Avatar
Default Duratool Desoldering Tool Emergency Tip Repair
This is by no means intended to be a fix but it will get you by until you can order a/some spare(s).
The tip on mine failed and wouldn't suck out the solder so I switched off and went for the spare I assumed I had. I didn't have one and I was mid job so I had to come up with something.
I found that the centre part of an appropriately sized rivet can be knocked out easily and will provide a perfect tube that can be press fitted into the end of the desoldering iron tip using a vice.
No more leak and with a little bit of filing, the 'refurbed' tip is very usable and will easily last until my order for more tips arrives. I usually file the end of old tips and keep them for point-to-point desoldering in valve equipment but such a tip is useless on PCBs. This solution, however, works perfectly.
Ti Pwun is offline
Old 17th Jun 2016, 1:14 pm   #2
Default Re: Duratool Desoldering Tool Emergency Tip Repair
Probably last for ages as all 'quick fixes' do!
Old 17th Jun 2016, 4:29 pm   #3
Ti Pwun
Ti Pwun's Avatar
Thumbs up Re: Duratool Desoldering Tool Emergency Tip Repair
I've been using it all day without any problems so I may see how long it lasts before fitting a new one. 'If it aint broke...' and all that.
EDIT: I think the rivet next to the tip is the next size up, by the way. Now that I'm looking I doubt I fitted a rivet that size inside the tip. There is one in there, though, and it is working very well.
Ti Pwun is offline
Old 18th Jun 2016, 2:40 pm   #4
McMurdo
McMurdo's Avatar
is that a steel or aluminium rivet?
Kevin
McMurdo is offline
Old 19th Jun 2016, 2:35 am   #5
Ti Pwun
Ti Pwun's Avatar
It's aluminium, but even though the intention was only to keep the tool working until my order for replacemrents came in, I use it at 360°C so it's nowhere near the 660(ish)°C needed to melt aluminium so I wasn't too worried about it.
It looks exactly as it did when I fitted it and it's hardly been off since then...
Ti Pwun is offline
Old 21st Jun 2016, 3:25 pm   #6
Ti Pwun
Ti Pwun's Avatar
Update:
The rivel finally failed this afternoon. Well, not so much failed but it did become loose and threatened to fall out a couple of times.
Still, as a temporary fix until more tips can be ordered, I would still recommend it if you're in the position that I was at the time. It had a lot of use in the days since it was fitted.
I will, of course, keep more than one or two spare tips in stock in future.
Ti Pwun is offline
