14th Jul 2020, 3:36 pm | #1 |
Philips reel to reel DIN wiring
Hi all
I plan to buy a DIN to 2 mono jack or 2 phono lead so that I can record some material from some old tapes. I seem to think that Phillips wired their DINs differently to others - have I made this up? I just want to check before I order one from ebay or wherever. Thanks Martin
Is it live, or is it... no, it's live actually... |
14th Jul 2020, 3:47 pm | #2 |
Re: Phillips reel to reel DIN wiring
Buy a DIN to 4 phonos and you will have covered all eventualities. Also get 2 Phono socket to Jack adaptors and you can use them as required.
14th Jul 2020, 3:51 pm | #3 |
That is good advice. Alternatively, if you are capable of making up your own cables, you can just work out which signal is on which pin by trial and error.
I think Philips followed the DIN standard for their line in/out sockets, but did some strange things with the mic socket. |
14th Jul 2020, 4:10 pm | #4 |
Cheers chaps.
Yes I can make cables, but something like this is usually cheaper to buy via ebay. Four phonos is a good idea!
14th Jul 2020, 10:17 pm | #5 |
Re: Philips reel to reel DIN wiring
Philips would often use the same pins for both input and output (pins 3 and 5 IIRC) - is that what you are thinking of? In this case the input would be designed to accept higher levels than the standard DIN input pins.
