14th Mar 2011, 12:15 pm | #21 |
Re: Wireless set recommendations please
14th Mar 2011, 6:34 pm | #22 |
How unkind ! there again......
A. |
14th Mar 2011, 8:30 pm | #23 | |
I expect one day I will see a wireless set that I like the look of and that will be that ! Graham |
17th Mar 2011, 7:50 pm | #24 |
Hi i also have a nest of Murphy radios, i cannot fault them, the retro looks on some may not please all but they sure do sound good, here is one of mine a A72 also, 1939 Murphy .....Alan.
20th Apr 2011, 6:43 pm | #25 |
I quite like the look of the set on this webpage - can anyone identify it please ?
http://www.angelradioisleofwight.moonfruit.com/ Thanks Graham |
20th Apr 2011, 7:07 pm | #26 |
If you are looking at something pre-war, don't forget you'll almost certainly need some kind of aerial; you can get away with a bit of wire strung about the room for the stronger stations. Unfortunately noise generated by your or your neighbours' modern electronic devices may rule this out and you may need to put your set by a window for an outside bit of wire, say 30 to 50 feet long.
Many/most sets from the late 40s onwards have an internal frame aerial so you don't need any aerial wires. Or you could put a little MW modulator close to the set and you can play anything you like even if the set "needs" an aerial. Regards, Ian |
20th Apr 2011, 7:37 pm | #27 |
Hello,
It's a Pilot. There is one on ebay at the moment :- http://cgi.ebay.co.uk/Vintage-art-de...item4158ba6d6b Yours, Richard |
20th Apr 2011, 7:40 pm | #28 |
Richard
Thanks - are they any good ? what is the spares situation like ? Also, did you see the post in the transport section ? Graham |
20th Apr 2011, 7:45 pm | #29 | |
This is something I had not really considered as all the sets I own have internal frame aerials. Better start working out the explanation to SWMBO..... I can always say it is a new washing line ? Graham |
20th Apr 2011, 9:00 pm | #30 | |
20th Apr 2011, 9:06 pm | #31 |
Ferguson, Pilot and some other USA/Canadian manufacturers set up subsiduaries in the UK. They use UX series USA valves which are a little more difficult to get than the B5/B7 series types but not impossible. Corrrosion often seems a problem with the american based sets but I wonder if it's more that the cabinets were better made and any UK set with a chassis that corroded would have been thrown out as the case would be worm ridden and de-laminated.
21st Apr 2011, 3:59 pm | #32 |
Yes, Wellbrook loops are excellent. I have installed a few professionally and am listening via one right now connected to an Icom R75 communications receiver. But they are a sledge hammer to crack a nut I suspect in this case, especially as they now start at £149! (www.wellbrook.uk.com). Depending on the model they cover from at least 100 kHz to well over 30 MHz, a bit of a waste if you just want LW and MW.
Theoretically they should be terminated in 50 ohms which an ordinary domestic set is unlikely to present, although I don't think it matter much in practice. A bit of wire (thin multi-stranded plastic covered will do - nothing fancy) poked through a window and tied to a tree or gutter via some non-conductive weather-proof cord will be as good as anything. Regards, Ian |
21st Apr 2011, 5:34 pm | #33 |
looking at the tuning gang,this set has been badly stored.
David |
21st Apr 2011, 5:53 pm | #34 | |
22nd Apr 2011, 10:27 am | #35 | |
I am not sure that your hypothesis for the corrosion on US sets can be substantiated though ! I am sure there are many other factors to consider ! Thanks Graham |
22nd Apr 2011, 10:50 am | #36 |
Hi Graham, There's many things that are going to deteriorate on a 70 year old radio and the anti-corrosion protection on the chassis is just one of them. It's something that can either be corrected, improved or just left as it is during a restoration.
With regards to aerials, I've got plenty of pre and post war radios, without internal aerials, that pick up plenty of strong stations with nothing more than 4' of wire hanging out the back HTH David |
12th May 2011, 5:04 pm | #37 |
I now have a Pye 39J/H courtesy of Setsappeal - you were right about the fluff on the inside - it's like a fur coat....
GR |
12th May 2011, 9:14 pm | #38 | |
15th May 2011, 10:12 am | #39 | ||
It defintely needs a decent aerial - there is no internal one on this set. I tried it with 5 ft of wire and it worked quite well, so with an external aerial and a bit of a service (not sure when though !) the set will work even better - that is if I ever prise it away from my mother who has decided it now belongs to her ! GR |
