27th May 2014, 11:29 pm | #1 |
Sony BMC-100P Door Screw
Hello at all,
It's possible to find today this screw, for the cassette compartment of the BMC-100P? Anyone have this type of screw? Thanks Again. Libra Last edited by AC/HL; 27th May 2014 at 11:44 pm. Reason: Image uploaded |
28th May 2014, 12:09 pm | #2 |
Re: Sony BMC-100P Door Screw
Measure the screw and then try searching ebay for:
sony screw You may find something that is similar if not identical, but you will need to know the size first. Good luck! |
29th May 2014, 12:55 am | #3 |
Thanks Maclee.
Libratron |
29th May 2014, 9:18 am | #4 |
They look an awful lot like screws used in laptop computers!! Could give that a try if you have any lying about.
Jan |
29th May 2014, 10:47 am | #5 |
Do you have one which you could post a picture of?
I suspect lots of top-loading domestic videos used similar screws, and we might have some in our scrap boxes if we knew the dimensions etc. N. |
29th May 2014, 11:34 am | #6 |
Is the head type important? I imagine it would be a standard metric thread, or possibly a self tapper.
29th May 2014, 2:08 pm | #7 |
ISTR these are sometimes non-magnetic specials. Or did I imagine that?!
29th May 2014, 9:36 pm | #8 |
I seem to recall reading that, while Japan does indeed use ISO Metric screw threads, the JIS specifies a different countersink angle from the ISO countersink used in Europe. The American McMaster-Carr catalogue used to list both types.
30th May 2014, 1:30 am | #9 |
Thanks very much at all!
The screw is completed missing. But in the service manual of the BMC-100 i think to find in the mechanism exlpode, the part number and the misure. Thanks again! Libra |
30th May 2014, 11:06 am | #10 |
Just checked and JIS countersunk head screws have the same countersink angle as the ISO, but the head is wider.
30th May 2014, 10:57 pm | #11 |
Thanks Emeritus.
Libra |
