23rd Sep 2019, 4:49 pm | #1 |
Valve Help
I have obtained a French radio from the early 1930s which runs off batteries
it has what I presume are 4 pin European valves running off an LT of 4V one valve in particular has no continuity and I need to replace it - I am having trouble identifying a suitable replacement the valve is marked ONYX on the side and on the top Philips A409 can anybody guide me in the right direction regards Dick |
23rd Sep 2019, 5:11 pm | #2 |
Re: Valve Help
Any help?
https://www.radiomuseum.org/tubes/tube_a409.html https://frank.pocnet.net/sheets/170/a/A409.pdf
Frank |
23rd Sep 2019, 6:44 pm | #3 |
Re: Valve Help
A PM3 might be used, maybe with attention to grid bias.
What's the set? Have you any circuit details?
23rd Sep 2019, 8:39 pm | #4 |
Re: Valve Help
Or you could use a 2V valve and a series resistor. Is it the detector?
