Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Other Discussions > Forum Announcements and Comments
Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval.
Old 29th Sep 2023, 3:37 pm   #1
Paul Stenning
Administrator
Paul Stenning's Avatar
Exclamation Forum offline this evening (29/09/2023)
This forum will be offline and may show error messages for up to an hour (but probably less) between 9pm and 10pm (UK time, GMT/UTC+1) this evening.
This is due to scheduled maintenance by the hosting company to update MySQL from 5.7 to 8.0.
If you are posting during that time please copy/paste your text elsewhere so it isn't lost and you can try later if the forum is offline when you submit it.
Paul Stenning
Forum Admin/Owner and BVWS Webmaster
Paul Stenning is offline
Old 29th Sep 2023, 3:48 pm   #2
Paul Stenning
Administrator
Default Re: Forum offline this evening (29/09/2023)
Depending on what time the maintenance finishes, I may not be able to remove the notice at the top of the page until tomorrow morning.
Paul Stenning
Old 29th Sep 2023, 10:57 pm   #3
Paul Stenning
Administrator
From error emails this appears to have taken around 90 minutes to complete. I don?t know if it was offline the whole time or up and down.
All appears to be working fine now. Apologies for the inconvenience.
Paul Stenning
Old 29th Sep 2023, 11:43 pm   #4
Graham G3ZVT
Graham G3ZVT's Avatar
Paul, I'm positive that the apostrophes in this thread
https://www.vintage-radio.net/forum/...d.php?t=203953
were displayed correctly last time I looked.
(codepage problem?)
edit.
The apostrophe in this post displays correctly as you can see.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 30th Sep 2023, 7:13 am   #5
Paul Stenning
Administrator
I think the default character set changing to UTF-8 with the MySQL update.
Probably the only option is to manually edit these threads and posts as we find them but I will see if there is a setting or configuration change first.
Paul Stenning
Old 30th Sep 2023, 8:14 am   #6
Station X
Station X's Avatar
I've edited that thread.
Graham. Forum Moderator
Station X is offline
Old 30th Sep 2023, 8:21 am   #7
Paul Stenning
Administrator
There is no easy solution to this. New threads and posts will be fine.
If anyone spots any other affected threads or posts please click the Report Post triangle icon and ask the mod team to edit it.
This probably happens due to text being copied/pasted from a word processor that changes apostrophises and quotes from straight to slanted.
Paul Stenning
Old 30th Sep 2023, 8:46 am   #8
Graham G3ZVT
I'm sure you have discovered by now it's affecting all the pound sign, and no doubt all the other usual suspects like the ampersand.
Graham.
G3ZVT
Old 30th Sep 2023, 8:48 am   #9
Paul Stenning
Administrator
I have just changed the HTML header character set from "ISO-8859-1" to "UTF-8", and set the database character set setting in the forum config file from "latin1" to "utf8" (to match the database default).
Let's see if that has helped or not...
Paul Stenning
Old 30th Sep 2023, 9:12 am   #10
Graham G3ZVT
That seems to have fixed it Paul, example, all the £ signs in "items offered" are now OK Well done!
Graham.
G3ZVT
