3rd May 2022, 7:48 pm | #1 |
Capacitor question.
Hi all . can anyone suggest a replacement for this please . It has 5 MFD printed on it
3rd May 2022, 7:55 pm | #2 |
Re: Capacitor question.
It's a 5uf. Find a close value at or above the top working voltage printed on the case.
3rd May 2022, 7:57 pm | #3 |
A modern 4.7uF electrolytic of the correct voltage rating should be OK.
3rd May 2022, 8:05 pm | #4 |
Ok .Thanks guys
3rd May 2022, 8:14 pm | #5 | |
B
3rd May 2022, 8:22 pm | #6 |
Agreed, nothing wrong with that. The value is unlikely to be critical.
3rd May 2022, 8:53 pm | #7 |
Aerolite...? Possibly made of Gordon-Aerolite, the early composite of flax and resin. (It's certainly the correct colour)
Dave |
4th May 2022, 12:30 pm | #8 |
I'm pretty certain this is an old paper/wax capacitor, and it's 0.5uF, not 5uF. Have a search on ebay: there's something very similar for sale in the US. If your capacitor is about the size of this one, it's almost certainly 0.5uF.
Vintage 1950s Aerovox Aerolite Wax Capacitor .5 uf 400v Crossover tone Cap https://www.ebay.co.uk/itm/115040895069 |
4th May 2022, 12:39 pm | #9 |
If we knew the capacitor's position in the circuit it would be possible to determine its likely value.
4th May 2022, 12:43 pm | #10 |
4th May 2022, 12:56 pm | #11 |
I agree, it's probably 0.5 MFd, the banded end marks the ground end of it.
worried about the electrons entering the circuit and the smoke leaving Andrew |
4th May 2022, 1:15 pm | #12 | |
The leading . was easy to rub off or become illegible, so a nominal 0.5uF capacitor could be mistaken for 5uF Craig
Doomed for a certain term to walk the night |
8th May 2022, 7:18 pm | #13 |
Capacitor question.
Hi all
i recently asked a question about the brow cap in the photo but cant seem to find the thread anywhere . What i wanted to know is weather the yellow caps would be a suitable replacement ., I found them in my box of stuff and wondered if they would do the job before i go buying new ones |
8th May 2022, 7:23 pm | #14 | |
Re: capacitor question
Lawrence. |
8th May 2022, 7:24 pm | #15 |
The other thread is here: https://www.vintage-radio.net/forum/...d.php?t=190859
The photo you have just posted is clearer and shows .5uF so you need 0.47uF not 4.7uF. |
8th May 2022, 8:14 pm | #16 |
thanks Simon .i couldn't find that thread anywhere
cheers |
8th May 2022, 10:56 pm | #17 | |
Yes, we got it wrong about the original value as we couldn't see the 'dot', which is now very visible on your latest photo. The line around the end of the capacitor indicates the outer foil connection, which must preferably be connected to the low impedance side of the circuit. |
9th May 2022, 10:25 am | #18 |
Threads merged.
9th May 2022, 3:19 pm | #19 |
sorry folks .i didn't know about the components section. after looking at a blown up photo of the brown cap i can now see the point before the 5 . In the photo you can see where they are in the circuit [down in the right hand bottom corner] . one end is connected to the centre tap on the contour control and the other end is on the two phono sockets .these have leads plugged into them that go off to the separate amplifier
9th May 2022, 3:59 pm | #20 |
It's more helpful if we can see the circuit diagram. It's not possible just by looking at the layout exactly what they do in the circuit. We can now be sure that they are 0.5uF though so it probably doesn't really matter.
