Old 24th Apr 2022, 5:34 pm   #21
DMcMahon
DMcMahon's Avatar
Default Re: Grundig TK 40 Reel to Reel Checkout
Prior to replacing the bridge rectifier I did a barrage of recording tests. Fairly consistently new recordings on all 3 speeds sounded far too fast (as previously reported) but old recordings always played at the correct speed. Checked all sorts of things but could not fix or understand the issue.
Post replacing the bridge rectifier all 3 speeds now playback new recordings (and old) very well, hard to understand how this can be.
The quality of the recordings seems really good even at 1 7/8" ips.
DMcMahon is offline
Old 11th May 2022, 8:06 pm   #22
DMcMahon
DMcMahon's Avatar
After re-assembling the unit, playback and recording still working very well.
There is a metal sprung loaded push button above the Record Key that when pressed releases a plastic tape cleaner piece. 2 felt cleaning pads can be fitted and can be used to clean the tape during fast forward winding.
First time I have seen this on board cleaner, more used to the stand alone cleaner that can be used on some of the other Grundig models where the cleaning piece has to be manually fitted and held in place while cleaning the tape.
Name:	Tape cleaner retracted.jpg
ID:	256992   Click image for larger version
Name:	Tape cleaner released.jpg
ID:	256993   Click image for larger version
Name:	Tape cleaner in Fast Forward Wind.jpg
ID:	256994   Click image for larger version
Name:	Stand alone tape cleaner.jpg
ID:	256995   Click image for larger version
DMcMahon is offline
