11th Mar 2022, 11:58 am | #21 |
Re: Clarke & Smith
The IFTs will likely contain (fixed) capacitors anyway even if they are slug tuned.
13th Mar 2022, 3:42 pm | #22 |
Re: Clarke & Smith
I realise the thread has moved on, but having just looked at that circuit I am interested to see the phase-splitter arrangement. A unity-gain inverting amplifier is a common use for an opamp but I don't think I've ever seen one like this in a valve audio amplifier.
13th Mar 2022, 9:14 pm | #23 |
Re: Clarke & Smith
It's relatively common - the paraphase phase inverter. As an example, the Soundmirror tape recorder uses this type of phase inverter. Its advantage is it is self-balancing with the valve characteristics having a pretty small influence on equality of the two outputs.
14th Mar 2022, 7:43 pm | #24 |
Re: Clarke & Smith
Be careful making any adjustments to the IFTs. I did this and the core disappeared into it.
Paul |
14th Mar 2022, 9:10 pm | #25 |
Re: Clarke & Smith
I've seen a few of this particular model over the years. For some reason they quite often appear naked without the wooden case. Like all their schools kit they were not built for aesthetic purposes but to a strict supply contract spec that is why the C&S and early goodsell and Coomber schools kit appears in a similar utilitarian giuse. Dates to mid 50s use of differant valve types is typical, ECC83 had probably not long come onto the market replacing an ECC40. C&S did like EBC41s and the octal EBC33s in the 1st gen schools kit strapped as troide amplifiers! Must have had a shed load! Unfortunelty I cannot help with a circuit . 88/8/2 designation indicates an 8 watt amp and second , later model
If anyone wants a copy of the dyeline scans for the 88/12 I have now had these digitised from originals via a large format scanner and they are much clearer to read. Just let me know via PM with your email as the files are too large to post here. Regards, Terry
Terry Martini-Yates BVWS Committee Vice Chair Last edited by terry123; 14th Mar 2022 at 9:17 pm. |
17th Mar 2022, 1:20 pm | #26 |
Re: Clarke & Smith
12th Apr 2022, 4:48 pm | #27 |
Re: Clarke & Smith
well, I've finished swapping out dubious components and switched on . . it receives much better than I'd hoped for [MW and LW only of course]
I was able to peak up the IF [465kHz] and align the tuning dial . . maybe revisit that sadly the EM34 'magic eye' doesn't glow and replacements are prohibitively expensive [also a 'pig in a poke'] so I'll probably run without one [or strap a green LED to the envelope to 'look right' !] ver 3 of my reverse engineered circuit is attached . . this is now pretty close what a pity that 69% of the resistors begin '47' as it makes tracing so much harder . . the 'On' indicator is a lens of soft red plastic through which the dial lamp shines . . at some point in the past it has been in contact with the bulb and is, to an extent, burned black . . if anyone knows of a replacement or a suitable fix then I'd be very pleased to hear from them my first valve project for fifty years, it has been fun . . |
13th May 2022, 12:03 pm | #28 |
Re: Clarke & Smith
This photo doesn't quite do it justice, but the the 'new old stock' 6E5 is in, replacing the EM34 . . I couldn't get hold of a neat 6pin socket for the 6E5 and had to make do with some huge ceramic thing, but the 'magic eye' works and, to my mind, brings the radio to life.
13th May 2022, 12:05 pm | #29 |
Re: Clarke & Smith
Lovely!
13th May 2022, 12:08 pm | #30 |
Re: Clarke & Smith
13th May 2022, 12:20 pm | #31 |
Re: Clarke & Smith
You might want to add a hidden switch round the back to give it a magic eye conserving mode.
