Old 11th May 2022, 8:40 pm   #41
Radio Wrangler
Radio Wrangler's Avatar
Default Re: Mr.French's Dynamic Mutual Conductance Tester.
34mA in the triode-connected list, 48mA in the pentode-connected list for the EL84, with appropriately different Vg1 bias values.... Enough to give a noticeable difference in Gm just from that, so the ratio of Ia to Ig2 is easily lost.
Radio Wrangler is online now
Old 12th May 2022, 9:52 am   #42
ms660
ms660's Avatar
I think there's a misunderstanding, do the calcs using the same Va-Vg voltages as the pentode, I make it not a lot of difference, compared to the KT88.
Lawrence.
ms660 is offline
Old 12th May 2022, 11:40 am   #43
Radio Wrangler
True, there is not a lot of difference. But we're going round the same circle again.
Strapping G2 to A to put a pentode or a tetrode into 'triode mode' for the purpose of measuring its Gm, as asked in post 33, does introduce a SMALL error in the result. Not strapping it avoids this error, so why not avoid the error and get a more accurate result.
Most people, if offered a choice between a 100 gramme and a 105 gramme bar of the same chocolate for the same price in a shop would not choose the disadvantaged deal. Even though the difference is small.
Errors are best avoided if they can be. If avoidance has a cost, then a judgement has to be made on whether it's worthwhile, but if it's easy then it's the proverbial no-brainer.
Small errors can be insidious, they can be cumulative, and systematic errors tend in this direction, so minimising errors is a good habit.
